Home > Td5 > Td5 and Dynamat
ibexman
Td5 and Dynamat
Has anyone actually performed any before and after noise level tests with Dynamat On decibel meter
Post #290506 15th Dec 2013 4:42pm
Likeomg
i have a decibel meter and a dynamated 2.4, i could try it against some other cars maybe? never thought to get a reading of mine before i did it
Post #290520 15th Dec 2013 5:15pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
I used silentcoat on mine (same principal as dynamat and almost identical construction). The description of where I applied it etc are on my TR51 thread ( http://www.defender2.net/forum/topic12967-15.html ).
Results:
Engine on, stationary Reduction : 8db
30mph in 3rd Reduction : 14db
50mph in 5th Reduction : 9db
70mph in 5th Reduction : 5db
I didn't do the engine bay, roof or wheel arches so if these rant exposed better results may be forthcoming Thumbs Up
Hope it helps.
Post #290541 15th Dec 2013 6:28pm
mk1collector
Dynamat alone will not make it a lot quieter. Dynamat is to stop vibrations, so drumming noises like from the big flat roof should be deadened. If you want noise reduction I suggest dynamat then a decent thickness of closed cell foam over the top and it makes a big difference, but the whole interior needs doing (and I mean everywhere) to make the biggest difference.
Post #290549 15th Dec 2013 6:41pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
When I did the front dynamated then added the wright off road kit dropped nearly 10db if I remember correctly was very crude iPhone app mind.
Post #290556 15th Dec 2013 6:58pm
Killer90
Site Sponsor
I am going to next year all organised ready to do a proper test Thumbs Up Got a TD5 in at the minute chris for full soundproofing Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #290594 15th Dec 2013 8:23pm
ibexman
Sounds good will wait to see results Thumbs Up
Post #290600 15th Dec 2013 8:38pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
we did a test on a td5 at work before and after and the results was quite good 11db reduction
that was using Skinz soundproofing from Four 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #290617 15th Dec 2013 9:36pm
Ken B
roughly what does it cost to do a full TD5 90 ? Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #291449 18th Dec 2013 4:50pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
That's impressive, I hope mine will be close to that then when I get around to taking out the interior and starting again. I will do a before and after test for people.
Has anyone used the dynamat tape to seal the joints up? 2004 TD5 Defender 90 xs station wagon
Post #291490 18th Dec 2013 8:03pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Not sure I agree. I've Noisekillered some of it and Dynamatted other bits over a period of time and driving before and after fitting Dynamat definitely made a difference to the level of noise. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #291504 18th Dec 2013 8:36pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
That will be due to the reduction in drumming noise, as well as a slight barrier to other noise.
But it isn't a noise barrier in itself. Other than the fact it is something else to travel through.
You need an anti-drumming layer (eg dynamat, silentcoat), followed by a thin layer of closed cell foam, followed by mass loaded vinyl - this is very dense and is a proper sound barrier
Post #291527 18th Dec 2013 10:10pm
Macpaul
Well I don't know the technicalities.
Just Dynamat less noise makes. 2003 Td5 110 Hardtop
Post #291546 18th Dec 2013 11:11pm
Sphere
Bow down
Post #291547 18th Dec 2013 11:12pm
mk1collector
As Diablo says you need a layered approach to stop different kinds and frequencys of noise for the best effect. Basically dynamat stops the car making its own noise (vibrations/drumming) with a slight reduction from other noise due to extra mass but is not in itself a noise barrier, so external noise will still be heard. Without going over the top and not being able to refit trim etc, a coat of dynamat (or similar) and say 6 to 10 mm thick closed cell foam (so it doesn't absorb water) is the best and most cost effective way to make a big difference in noise and as a bonus cuts down on condensation during winter months Thumbs Up
Post #291602 19th Dec 2013 11:01am
