Home > Puma (Tdci) > drained some fuel off....
Caterham
and found what looks like crude oil at the bottom....I guess its normal (?) but what is it?
and after a few days....
oh.... I thought I knew how to do the photo thing but now I'm not so sure?
Post #265481 11th Sep 2013 8:11am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Caterham, I don't think that's normal. I would expect any fuel to have a homogenous appearance.
Raises a few questions but I guess you probably know the answers.
Cheers,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #265512 11th Sep 2013 9:07am
Happyoldgit
Drained from where - the fuel filter? Steve.
http://forums.lr4x4.com
Post #265522 11th Sep 2013 9:32am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Looks very similar to what I get when I drain of a bit of diesel from my fuel filter. I have been told it's algae, but hopefully someone else can confirm / refute that.
Post #265526 11th Sep 2013 9:39am
Caterham
MOG - yes from the bottom of the filter (which I guess its shows its doing what it should?)
bearing in mind I don't 'off road' it and the fact its always been like that makes me think its simply the quality of the fuel?
I'm confident its not algae or similar but some kind of oil based liquid. that said I guess if its simply dirty water that would sink too??
as said not too concerned / its normal but a little surprsing all the same?
Post #265530 11th Sep 2013 9:45am
robharvey
Double post, apologies.
Post #265532 11th Sep 2013 9:47am
Naks
This is why every 5000km or so I chuck in a bottle of Wynns Diesel Cleaner Thumbs Up --
Post #265544 11th Sep 2013 10:06am
Happyoldgit
Indeed the filter is doing what it should and that is helping to prevent crud from bulk tanks etc making it through to the noisy end of the vehicle Thumbs Up Steve.
Post #265552 11th Sep 2013 10:20am
ARC99
I may be totally wrong here but this is my understanding.
The Bio that the put into fuel is still a live thing (not dead) and it will continue to grow even in fuel and has been known to completely block filters and fuel lines. I have not had the problem myself but know a of two people that had the problem.
I own a caravan and for sometime now I have had to regularly clean out the flush system as they have started to put a bio additive in the chemical flush and that grows unless killed off with a product known to kill all known germs. Don't make old people mad.
Richard
Post #265555 11th Sep 2013 10:23am
Caterham
thanks Steve.
might be bio stuff..... I think I'm gonna try and collect more of it to try and understand what the crud is....
perhaps it is bio?
does anyone else drain the filter on a regular basis and do you find the same?
Post #265800 11th Sep 2013 9:16pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
It looks like sludgy water, perhaps with a bit of "diesel bug"
Post #265805 11th Sep 2013 9:23pm
Cheshire110
Errm. No, sorry. Dad makes biodiesel (proper stuff not the 6-10% mix in standard road fuel) and there is nothing 'living in it'. BIOdiesel simply means that the oil from which the diesel is produced (ie waste chip pan, rape seed oil etc) is of a 'renewable' (don't go there) source.
Besides petrol station / supermarket fuel is only 5-10% bio at the most.
Answering the original question, I drained mine the other week and just got a little bit of fine sediment and some brownish fuel, followed by clean fuel. What you have just looks like a bit of gunk, nothing to worry about IMO - filter doing it's job. Cheers, David
Post #265832 11th Sep 2013 11:19pm
Caterham
someone else that make bio...... Very Happy
same here looks like a bit of 'brown fuel' and then all clear.
as mentioned not concerned its always been like it but more wondering if its in fuel to start with or getting in from somewhere else.?
might try running the car on a low tank and just topping up a little at a time to see if makes any difference?
Post #265890 12th Sep 2013 7:13am
appaloosadude
I'm not familiar with the fuel drain on a Puma, but if it is like a TD5, road dirt and muck can end up sat in the drain and will be ejected when one opens the drain, thus giving you what appears to be really mucky fuel.
Post #265891 12th Sep 2013 7:15am
Cheshire110
I wouldn't worry about it... That must have been filtered out of a number of tanks of fuel and built up since you last drained / changed filter.
Mine was much worse after I picked up some cr*p fuel the other week , and Censored my 110 up! (Not necessarily directly the fault of the fuel) Cheers, David
Post #265892 12th Sep 2013 7:19am
