Home > Maintenance & Modifications > Best primer for cappings.
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Hi,
Just wondering if anybody has any suggestions for a good primer for my cappings. Im going to shot blast them while there on as its only a few spots next to the rear door that need doing. I got a pack of rattle cans from land rover for the colour and top coat but need some primer in a can too. Any suggestions?
Thanks.
Pete.
Post #239160 28th May 2013 9:36am
mikeh501
some self etching primer would be fine id guess. maybe go over it with high build primer then topcoat it.
Post #239241 28th May 2013 1:41pm
This:
http://www.ebay.co.uk/itm/300708024124
A couple of coats should be fine unless there is a lot of surface imperfections. Be sure to lightly flat it before base coating for a glossy perfect finish. The rest I'm sure you already know. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #239281 28th May 2013 4:00pm
Retroanaconda
Why don't you get them galved? Then paint over the top in desired colour.
That way you can fit and forget.
Post #239340 28th May 2013 5:57pm
Zinke
Got some etch primer today and some hi build to go over the top.
I will be doing that when I get chance but as I work in my defender most days it's hard to find time to take the roof off and remove the cappings and getting them galv and painted. Will do it when I need a new chassis I guess.
Thanks.
Pete.
Post #239388 28th May 2013 9:03pm
