Home > Maintenance & Modifications > Best primer for cappings. |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Hi,
Just wondering if anybody has any suggestions for a good primer for my cappings. Im going to shot blast them while there on as its only a few spots next to the rear door that need doing. I got a pack of rattle cans from land rover for the colour and top coat but need some primer in a can too. Any suggestions? Thanks. Pete. |
28th May 2013 10:36am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
some self etching primer would be fine id guess. maybe go over it with high build primer then topcoat it.
28th May 2013 2:41pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19728 |
This:
http://www.ebay.co.uk/itm/300708024124 A couple of coats should be fine unless there is a lot of surface imperfections. Be sure to lightly flat it before base coating for a glossy perfect finish. The rest I'm sure you already know. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
28th May 2013 5:00pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2575 |
Why don't you get them galved? Then paint over the top in desired colour.
That way you can fit and forget. |
28th May 2013 6:57pm |
Got some etch primer today and some hi build to go over the top.
I will be doing that when I get chance but as I work in my defender most days it's hard to find time to take the roof off and remove the cappings and getting them galv and painted. Will do it when I need a new chassis I guess. Thanks. Pete. |
28th May 2013 10:03pm |
