Home > Maintenance & Modifications > Fender lockers |
Mudstuff do them and they are a one for one swap with the blank, about a 5 minute fit. With regards to the CTEK the easiest solution is to route a cable from under the wing downwards and rearwards direct through the side of the battery box via an existing gland (or add an extra gland (something like a Marine Index one) and into the battery bay. I would not go through the bulkhead as this would make things more difficult. Maybe no more than a couple of hours toil.
http://www.mudstuff.co.uk/products/securit...ocker.html http://www.indexmarine.co.uk/deck-glands-aluminium.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th May 2013 4:58pm |
Think with regard to the Ctek,..... this is an easier solution
http://www.defender2.net/forum/topic20342.html?highlight=ctek You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
19th May 2013 5:16pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Why don't you fit a solar charge system for the time it's going to sit around in the yard
That said the current drain is not like a D3 Welcome |
19th May 2013 5:37pm |
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 |
Cheers guys. Definitely the way I want to go as I don't want the 110 unsecured if I need to charge the battery.
19th May 2013 5:58pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Got one on mine Jason
Click image to enlarge |
19th May 2013 7:10pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3465 |
What's in yours ? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
19th May 2013 7:27pm |
The other end of this ARB compressor Click image to enlarge |
19th May 2013 7:37pm |
