![]() | Home > Maintenance & Modifications > Fender lockers |
Mudstuff do them and they are a one for one swap with the blank, about a 5 minute fit. With regards to the CTEK the easiest solution is to route a cable from under the wing downwards and rearwards direct through the side of the battery box via an existing gland (or add an extra gland (something like a Marine Index one) and into the battery bay. I would not go through the bulkhead as this would make things more difficult. Maybe no more than a couple of hours toil.
http://www.mudstuff.co.uk/products/securit...ocker.html http://www.indexmarine.co.uk/deck-glands-aluminium.html ![]() Treat every day as if it is your last....one day you will be right!! |
Think with regard to the Ctek,..... this is an easier solution
![]() http://www.defender2.net/forum/topic20342.html?highlight=ctek You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Why don't you fit a solar charge system for the time it's going to sit around in the yard
That said the current drain is not like a D3 ![]() ![]() |
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 ![]() ![]() |
Cheers guys. Definitely the way I want to go as I don't want the 110 unsecured if I need to charge the battery.
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Got one on mine Jason
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3496 ![]() ![]() ![]() |
What's in yours
![]() 1995 110 300TDI 1995 90 300TDI |
The other end of this ARB compressor ![]() ![]() Click image to enlarge |
