Home > Maintenance & Modifications > Fender lockers
Innuendomaster
Fender lockers
I'm thinking of fitting one of these with a CTEK comfort charger inside. How easy would this be as I've just realised the battery is under the seat Laughing
Anybody got one fitted? Where did you get it?
Post #236863 19th May 2013 4:41pm
K9F
Mudstuff do them and they are a one for one swap with the blank, about a 5 minute fit. With regards to the CTEK the easiest solution is to route a cable from under the wing downwards and rearwards direct through the side of the battery box via an existing gland (or add an extra gland (something like a Marine Index one) and into the battery bay. I would not go through the bulkhead as this would make things more difficult. Maybe no more than a couple of hours toil.
http://www.mudstuff.co.uk/products/securit...ocker.html
http://www.indexmarine.co.uk/deck-glands-aluminium.html
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #236871 19th May 2013 4:58pm
ericvv
Post #236877 19th May 2013 5:16pm
Why don't you fit a solar charge system for the time it's going to sit around in the yard
That said the current drain is not like a D3 Thumbs Up Welcome Wink
Post #236878 19th May 2013 5:37pm
Innuendomaster
Cheers guys. Definitely the way I want to go as I don't want the 110 unsecured if I need to charge the battery.
Post #236882 19th May 2013 5:58pm
SGH
Got one on mine Jason
Post #236912 19th May 2013 7:10pm
familymad
What's in yours Whistle ? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #236927 19th May 2013 7:27pm
SGH
The other end of this ARB compressor Smile
Post #236942 19th May 2013 7:37pm
