Page 1314 of 1392 <123 ... 131313141315 ... 139013911392>
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Itching to fit my Mantec RAI (purchased a few days earlier from a fellow forum member). It had rained every day since it had been delivered. As I don’t like leaving drilled holes unpainted and with the rain looking like it’s here for a good while yet, I had to resort to the trusty golf umbrella. I don’t play golf but this bit of kit came in handy keeping the rain off the wet paint. My B&D hot air gun speeded up the drying time.
Post #904384 22nd May 2021 8:02am
rockster57 wrote:
Supacat wrote:
rockster57 wrote:
The vice secured the sheet metal folder i recently bought on ebay from "tinman".
Thumbs Up
Got some photos of that?
Looks an excellent effort Thumbs Up
Thank you for the compliment. I’m pleased with how it all turned out. This is the folder...
It’s not exactly a precision instrument, more of a home workshop type fabrication utilising angle iron but it did the job well without any drama. Coped fine with the sizes of 3mm plate I used for the brackets. I would have preferred a longer handle for more leverage but that said, I’ve been planning out an extended workbench project so none of my bench mounted equipment is bolted down at the moment - including the vice in which the folder is clamped. A length of tube over the handle would have helped but you know how it is - as soon as we have a garage clear out, we find a pressing need for something we’ve just thrown out! Rolling Eyes
Thanks ~ off to look at his products. Thumbs Up
Post #904385 22nd May 2021 8:07am
bodstruck
Managed to get the bottom of my inoperative difflock. Caused all sorts of strife during a day's laning in Dartmoor a couple of weeks ago. I couldn't even persuade it in with a screwdriver from underneath. Most odd.
I suspected it was a bit seized from lack of use by the previous owner so set about taking off the carpets and gaiter to try and lube it up.
Turns out the problem was the rubber gearstick gaiter. The aperture for the HL lever was not wide enough to allow full sideways movement to engage the difflock. I changed it for the one from my TD5 which is stripped while it awaits decent weather for a paint job.
Side by side:
And the duffer from underneath:
Difflock works perfectly now Very Happy Thumbs Up
Post #904431 22nd May 2021 2:26pm
L110CDL
The one on the right is what i have on Millie, not sure what year the " duffer " one is from, good you got it sorted Thumbs Up Clayton.
Keeper.
Post #904833 24th May 2021 10:17pm
L110CDL
nitram17 wrote:
L110CDL wrote:
First for me as i drove and parked up on some special ground
Cool
you really have a great job fella!
Many thanks nitram 17 Thumbs Up Clayton.
Keeper.
Post #904834 24th May 2021 10:22pm
L110CDL
Rkcorry wrote:
Cool
Great picture this one , just inside the boundary.... Very Happy
Well, i was well in the boundary until the groundsman moved it Laughing to where it is now as he was cutting the grass Thumbs Up Clayton.
Keeper.
Post #904837 24th May 2021 10:26pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Today I pulled into the garage, unloaded my stuff, had some fun with the dog and then hopped right in, and very slowly backed into the park with the door still open. Embarassed Embarassed DOH
Luckily it appears to only have damaged the bottom corner of the door.
 Roaming around 🇳🇴🇨🇭
Post #905089 26th May 2021 12:39pm
Angus_Beef
double Roaming around 🇳🇴🇨🇭
Post #905090 26th May 2021 12:40pm
Ouch Sad Darren
Post #905092 26th May 2021 12:43pm
Pacha
Finally got to fit the Bluesea Terminals.
Great improvement!
 Rgds.
Chris
Post #905667 29th May 2021 9:52pm
nitram17
Hi do you know the biggest fuse you can use or total rating for that blue sea unit?It looks a neat option if your not planning on wiring the star ship enterprise.
Post #905701 30th May 2021 10:02am
nitram17
Post #905702 30th May 2021 10:03am
nitram17
Post #905703 30th May 2021 10:03am
Pacha
Post #905714 30th May 2021 11:36am
Went and did the dishes.
 QRZ 2e0vpf
Post #905744 30th May 2021 5:39pm
