Thanks ~ off to look at his products. ![]() |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1007 ![]() ![]() |
Managed to get the bottom of my inoperative difflock. Caused all sorts of strife during a day's laning in Dartmoor a couple of weeks ago. I couldn't even persuade it in with a screwdriver from underneath. Most odd.
I suspected it was a bit seized from lack of use by the previous owner so set about taking off the carpets and gaiter to try and lube it up. Turns out the problem was the rubber gearstick gaiter. The aperture for the HL lever was not wide enough to allow full sideways movement to engage the difflock. I changed it for the one from my TD5 which is stripped while it awaits decent weather for a paint job. Side by side: ![]() Click image to enlarge And the duffer from underneath: ![]() Click image to enlarge Difflock works perfectly now ![]() ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
The one on the right is what i have on Millie, not sure what year the " duffer " one is from, good you got it sorted ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Many thanks nitram 17 ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well, i was well in the boundary until the groundsman moved it ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Today I pulled into the garage, unloaded my stuff, had some fun with the dog and then hopped right in, and very slowly backed into the park with the door still open.
![]() ![]() Luckily it appears to only have damaged the bottom corner of the door. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇭 |
double Roaming around 🇳🇴🇨🇭
Ouch
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Finally got to fit the Bluesea Terminals.
Great improvement! ![]() Click image to enlarge ![]() Click image to enlarge Rgds. Chris |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Hi do you know the biggest fuse you can use or total rating for that blue sea unit?It looks a neat option if your not planning on wiring the star ship enterprise.
It's this one:-
https://www.mudstuff.co.uk/collections/fus...1460764757 Rgds. Chris |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Went and did the dishes.
![]() Click image to enlarge QRZ 2e0vpf |
