Home > Maintenance & Modifications > Advice replacing rear brake discs and pads
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Hi
My rear brakes are due for replacement on my Td5 90.
Is there an obvious upgrade I can do? Do 110 discs fit and offer superior performance? Any brand to use or avoid? Are the latest puma parts the same as Td5?
Many thanks
Post #224921 5th Apr 2013 6:13pm
Glynparry25
Other than 'performance' disks/ pads there isn't much you can do without huge work. Tdi, Td5 and puma are the same (just make sure it is for ABS if you have it).
110 rear brakes are the same as 90 other than that they are a different offset so WON'T fit.
Glyn Dog Sheep
Post #224931 5th Apr 2013 6:42pm
GUM97
Try and avoid Britpart Rolling Eyes An engine to TDi for!
Post #224933 5th Apr 2013 6:47pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I've just upgraded all four discs to EBC drilled and grooved with Greenstuff pads. Haven't had to use them in an emergency yet but I've noticed they don't fade like the standard set up did. Smile
Post #224934 5th Apr 2013 6:47pm
TD5_90
Thanks for the info.
Had a quick look and there appears to be vented or solid or drilled and grooved.
I take it solid is standard? What's the preference over vented or drilled etc?
Thanks
Post #225169 7th Apr 2013 9:03am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You can fit later 110 rear brakes as they use the rover axle instead of the Salisbury but you will need discs pads and calipers as the disc is bigger
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #225264 7th Apr 2013 6:12pm
landy andy
Did not think you could get rear vented discs?
But I have just replaced all my callipers, changed the front from solid to vented, and fitted grooved and drilled discs. At the moment AP callipers are on special offer at paddocks. Thumbs Up
Andy
Post #225268 7th Apr 2013 6:16pm
rustyboxx
Nah, the rears are solid. The original front discs were vented Smile
Post #225273 7th Apr 2013 6:26pm
I thought there was a difference between 110 & 90 (maybe rears only?) where 110 are vented all round & 90 aren't. Not sure if 110 rears would fit but swapping out solid ones might be seen as a performance upgrade...
Post #225349 8th Apr 2013 6:43am
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
[quote="GUM97"]Try and avoid Britpart Rolling Eyes[/quote]
I have just replaced rear pads with OEM Britpart XD kit and they are excellent. No noise and braking is also not bad at all.
Post #226364 11th Apr 2013 4:24pm
