![]() | Home > Maintenance & Modifications > Advice replacing rear brake discs and pads |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Other than 'performance' disks/ pads there isn't much you can do without huge work. Tdi, Td5 and puma are the same (just make sure it is for ABS if you have it).
110 rear brakes are the same as 90 other than that they are a different offset so WON'T fit. Glyn |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Try and avoid Britpart
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548
I've just upgraded all four discs to EBC drilled and grooved with Greenstuff pads. Haven't had to use them in an emergency yet but I've noticed they don't fade like the standard set up did.
| TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89
Thanks for the info.
Had a quick look and there appears to be vented or solid or drilled and grooved. I take it solid is standard? What's the preference over vented or drilled etc? Thanks |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 568
You can fit later 110 rear brakes as they use the rover axle instead of the Salisbury but you will need discs pads and calipers as the disc is bigger
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Did not think you could get rear vented discs?
But I have just replaced all my callipers, changed the front from solid to vented, and fitted grooved and drilled discs. At the moment AP callipers are on special offer at paddocks. Andy |
Nah, the rears are solid. The original front discs were vented
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
I thought there was a difference between 110 & 90 (maybe rears only?) where 110 are vented all round & 90 aren't. Not sure if 110 rears would fit but swapping out solid ones might be seen as a performance upgrade...
| dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173
[quote="GUM97"]Try and avoid Britpart
I have just replaced rear pads with OEM Britpart XD kit and they are excellent. No noise and braking is also not bad at all. |
| All times are GMT |
