Home > Puma (Tdci) > winch not moving
Page 2 of 2 <12
jst
i said i personally would fit an albright. there is nothing to stop one being mounted externally on any make or model of winch.
you are just bypasing what is in the bridge which can then be removed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212993 21st Feb 2013 5:19pm
jst
from the photo it looks like an 'i' to me. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212994 21st Feb 2013 5:20pm
Looking again at the photo (on a pc rather than a phone this time) and I have no doubt that you're right, it is an "i".
Post #213013 21st Feb 2013 7:08pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Well......I think I over torqued it.......
Post #213173 22nd Feb 2013 9:15am
Marius
Ok so my stupidity will come at a price.
Ill just have to fit a new solenoid unit. Drill out the rivets
Holding the old one in place. These damm things are just so damm pricy over here.
Post #213635 23rd Feb 2013 7:17pm
jst
the warn ones are pricy evey where hence the comment to fit an albright. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #213644 23rd Feb 2013 7:55pm
Marius
But from what I gathered the albrights does not fit in that same solenoid housing? Or am I wrong
Post #213925 24th Feb 2013 6:53pm
jst
correct, hence
leave the bridge empty and run 3 longer wires to an albright up in the engine bay where it is out of harms way. prob cheaper than buying a warn solenoid too, certainly more reliable. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #213994 24th Feb 2013 8:46pm
Marius
Can someone give clarity as to the exact albright model / part number? I assume they make many different types of solenoids. And I assume you are still running 4 of them (same as warn?)
Post #214086 25th Feb 2013 6:15am
No, the Albright is a single unit containing all the necessary indiviual solenoids.
See Albright Solenoid at Devon 4x4
Post #214106 25th Feb 2013 8:31am
jst
as ^^^^
just one of them. power in, F1, F2 and A out and then 3 wires for the switching side of it
goodwinch do them too, will see if i can find the wiring dia. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #214170 25th Feb 2013 2:06pm
jst
https://www.defender2.net/gallery/albums/u...wiring.pdf Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #214185 25th Feb 2013 2:59pm
Page 2 of 2 <12
