![]() | Home > Puma (Tdci) > winch not moving |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
from the photo it looks like an 'i' to me. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Looking again at the photo (on a pc rather than a phone this time) and I have no doubt that you're right, it is an "i". |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Well......I think I over torqued it.......
Ok so my stupidity will come at a price.
Ill just have to fit a new solenoid unit. Drill out the rivets Holding the old one in place. These damm things are just so damm pricy over here. |
the warn ones are pricy evey where hence the comment to fit an albright. Cheers
But from what I gathered the albrights does not fit in that same solenoid housing? Or am I wrong
correct, hence
leave the bridge empty and run 3 longer wires to an albright up in the engine bay where it is out of harms way. prob cheaper than buying a warn solenoid too, certainly more reliable. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Can someone give clarity as to the exact albright model / part number? I assume they make many different types of solenoids. And I assume you are still running 4 of them (same as warn?)
No, the Albright is a single unit containing all the necessary indiviual solenoids.
See Albright Solenoid at Devon 4x4 |
as ^^^^
just one of them. power in, F1, F2 and A out and then 3 wires for the switching side of it goodwinch do them too, will see if i can find the wiring dia. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
https://www.defender2.net/gallery/albums/u...wiring.pdf Cheers
