|  | Home > Puma (Tdci) > winch not moving |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | from the photo it looks like an 'i' to me. Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  21st Feb 2013 5:20pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      |
 Looking again at the photo (on a pc rather than a phone this time) and I have no doubt that you're right, it is an "i". | ||
|  21st Feb 2013 7:08pm |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231      | Well......I think I over torqued it....... | ||
|  22nd Feb 2013 9:15am |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231      | Ok so my stupidity will come at a price.
 Ill just have to fit a new solenoid unit. Drill out the rivets Holding the old one in place. These damm things are just so damm pricy over here. | ||
|  23rd Feb 2013 7:17pm |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | the warn ones are pricy evey where hence the comment to fit an albright. Cheers
|  23rd Feb 2013 7:55pm |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231      | But from what I gathered the albrights does not fit in that same solenoid housing? Or am I wrong | ||
|  24th Feb 2013 6:53pm |
 correct, hence
 leave the bridge empty and run 3 longer wires to an albright up in the engine bay where it is out of harms way. prob cheaper than buying a warn solenoid too, certainly more reliable. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  24th Feb 2013 8:46pm |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231      | Can someone give clarity as to the exact albright model / part number? I assume they make many different types of solenoids. And I assume you are still running 4 of them (same as warn?) | ||
|  25th Feb 2013 6:15am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | No, the Albright is a single unit containing all the necessary indiviual solenoids.
 See Albright Solenoid at Devon 4x4 | ||
|  25th Feb 2013 8:31am |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | as ^^^^
 just one of them. power in, F1, F2 and A out and then 3 wires for the switching side of it goodwinch do them too, will see if i can find the wiring dia. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  25th Feb 2013 2:06pm |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | https://www.defender2.net/gallery/albums/u...wiring.pdf Cheers
|  25th Feb 2013 2:59pm |
| Posting Rules
