Home > In Car Electronics > Speaker Adapter?
J8GHX
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Speaker Adapter?
Quick question:-
Is there such a thing as a speaker 'adapter ring' which will allow fitment of 130mm speakers in the factory (Puma) under-dash 100mm speaker location?
I have no desire to cut my dashboard around, but like the idea of a larger speaker (which seem to be a little better value than 100mm speakers!)
Your advice / input is appreciated in advance as always...........
John. Currently....... all gone...... pending delivery of a mid life crisis.......
Previously..... Quite a few! I really am a sucker for them!
Post #209149 7th Feb 2013 11:54am
GUM97
Is this the sort of thing you're looking for?
http://www.mudstuff.co.uk/products/in-car-...allow.html An engine to TDi for!
Post #209150 7th Feb 2013 12:00pm
J8GHX
Thanks GUM97,
I had seen those, but I don't understand how they'd work.
They only appear to have straight through holes, so I don't see how they'd allow a 130mm speaker to fit in a 100mm speaker space?
I would have thought there would have been two 'rings' in them - one to fit the 100mm dash hole and one to fit the 130mm speaker?
JH Currently....... all gone...... pending delivery of a mid life crisis.......
Post #209154 7th Feb 2013 12:14pm
I was looking at it too just the other day just the same idea as you. I too couldn't work out how they fit and work. in the end I just thought as I originally did that A. I don't like the look of them proud of the dash and not flush and B. that the power difference wasn't enough to change over something like 5w RMS each so pointless really.
All they had to do was to a picture write up of each step of the fitting process. Rolling Eyes ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #209168 7th Feb 2013 1:33pm
J8GHX wrote:
Thanks GUM97,
JH
Speakers tend to taper John.
You would be able to get most of a 130mm speaker into a 100mm hole, this just accommodates the last 16mm in depth.
It won't work with all 13cm speakers only shallow ones
Post #209172 7th Feb 2013 1:59pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Is there anything about to fit something like a 6x9 in the back too without taking a saw to it? Darren
Post #209267 7th Feb 2013 7:28pm
I would doubt it. Not only that I would doubt the magnet would even fit in the 10cm hole anyway without cutting. Even if it did it wouldn't sound good as the air would be partially trapped. Only way is to cut. Saying that you can buy 6x9 rear panels already made. Thumbs Up ____\We|Will|Win/___
Post #209271 7th Feb 2013 7:35pm
ibexman
Dont you know anyone whos handy with a router and mdf Thumbs Up
Post #209292 7th Feb 2013 8:39pm
Likeomg
someone does do a 6x9 for the rear corners... forget who tho sorry
Post #209300 7th Feb 2013 8:51pm
Used to be Defendoor I think but no longer do it. ____\We|Will|Win/___
Post #209306 7th Feb 2013 9:04pm
