![]() | Home > In Car Electronics > Speaker Adapter? |
Is this the sort of thing you're looking for?
http://www.mudstuff.co.uk/products/in-car-...allow.html An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
J8GHX Member Since: 22 May 2012 Location: Hampshire Posts: 154 ![]() ![]() ![]() |
Thanks GUM97,
I had seen those, but I don't understand how they'd work. They only appear to have straight through holes, so I don't see how they'd allow a 130mm speaker to fit in a 100mm speaker space? I would have thought there would have been two 'rings' in them - one to fit the 100mm dash hole and one to fit the 130mm speaker? JH Currently....... all gone...... pending delivery of a mid life crisis....... Previously..... Quite a few! I really am a sucker for them! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
I was looking at it too just the other day just the same idea as you. I too couldn't work out how they fit and work. in the end I just thought as I originally did that A. I don't like the look of them proud of the dash and not flush and B. that the power difference wasn't enough to change over something like 5w RMS each so pointless really.
All they had to do was to a picture write up of each step of the fitting process. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Speakers tend to taper John. You would be able to get most of a 130mm speaker into a 100mm hole, this just accommodates the last 16mm in depth. It won't work with all 13cm speakers only shallow ones |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Is there anything about to fit something like a 6x9 in the back too without taking a saw to it? Darren
I would doubt it. Not only that I would doubt the magnet would even fit in the 10cm hole anyway without cutting. Even if it did it wouldn't sound good as the air would be partially trapped. Only way is to cut. Saying that you can buy 6x9 rear panels already made. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Dont you know anyone whos handy with a router and mdf
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
someone does do a 6x9 for the rear corners... forget who tho sorry
Used to be Defendoor I think but no longer do it. ____\We|Will|Win/___
