Home > Maintenance & Modifications > Steering column play
grafty99
After my MOT this year I had two advisories, one being a worn shock bush (sorted) and the other is slight play in steering column. On closer investigation it appears that both the top and bottom UJ in the steering column have play. This does relate to play at the steering wheel, which I had assumed was the slack in my steering box. My question is, can the UJ's be replaced like the prop shaft ones or is it a new section of column from the bulkhead to the box?
If it is I have one hell of a bill coming because LR want £206 for a new one! Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #207075 31st Jan 2013 12:39pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Looked up microcat via link of forum.
part is QMN500270 lower steering column, googling the part, first supplier 80.87£
There is a U-joint repair kit QLE500020 at 32.2£ but this is the bottom U-joint only
Smile
Post #207077 31st Jan 2013 12:50pm
trying to get the steering shaft bush & bearing is impossible.
the bearing has numbers on it, but they aren't available anywhere...it seems LR (or their steering shaft supplier) have it all sewn up to themselves.
Post #207085 31st Jan 2013 2:09pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
have you tried e-bay?
there are listing for the uj's but i don't know if the are they correct one's you want.
Post #207095 31st Jan 2013 3:10pm
tatra805
overlooked the fact that you have a TD5 not a puma
RTC4738 lower column 82.64£ orig non LR and 39£ britpart 232£ LR
NRC7387 top joint 25 - 9 - 43 £
NRC7704 lower joint 24 - 8.5 - 43 £
Smile
Post #207117 31st Jan 2013 5:03pm
grafty99
Sorry should have said it was a Td5, Thanks for all the replies, better get shopping! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #207118 31st Jan 2013 5:05pm
Sorry, mis-read the original post... thought you meant the actual bearings IN the steering column, as opposed to the UJ's on the shaft. Embarassed
Post #207187 31st Jan 2013 9:03pm
grafty99
That's ok, I think I know what bits I need, I'll pop up the part numbers on here so I can confirm what bits I mean Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #207245 31st Jan 2013 11:33pm
