![]() | Home > Maintenance & Modifications > Steering column play |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
After my MOT this year I had two advisories, one being a worn shock bush (sorted) and the other is slight play in steering column. On closer investigation it appears that both the top and bottom UJ in the steering column have play. This does relate to play at the steering wheel, which I had assumed was the slack in my steering box. My question is, can the UJ's be replaced like the prop shaft ones or is it a new section of column from the bulkhead to the box?
If it is I have one hell of a bill coming because LR want £206 for a new one! ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
Looked up microcat via link of forum.
part is QMN500270 lower steering column, googling the part, first supplier 80.87£ There is a U-joint repair kit QLE500020 at 32.2£ but this is the bottom U-joint only ![]() |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
have you tried e-bay?
there are listing for the uj's but i don't know if the are they correct one's you want. |
overlooked the fact that you have a TD5 not a puma
RTC4738 lower column 82.64£ orig non LR and 39£ britpart 232£ LR NRC7387 top joint 25 - 9 - 43 £ NRC7704 lower joint 24 - 8.5 - 43 £ ![]() |
Sorry should have said it was a Td5, Thanks for all the replies, better get shopping! 2002 90 Td5 Station Wagon
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
Sorry, mis-read the original post... thought you meant the actual bearings IN the steering column, as opposed to the UJ's on the shaft.
That's ok, I think I know what bits I need, I'll pop up the part numbers on here so I can confirm what bits I mean
