Home > Technical > 2002 110 td5 strange hiccuping or slight hestigation?
Page 2 of 2 <12
Welshsurferdude
Wales
Ok list of things to do tomorrow morning is to
Check ECU plug for oil
Check turbo wastegate for freedom of movement
Check fuel regulator for leaks, as it diesel will the leak show up easily? 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #189650 29th Nov 2012 10:02pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Normally yes, you'll see it collecting underneath
Post #189679 29th Nov 2012 10:48pm
landy andy
Is yours remapped?.
Mine does this at very high revs if I fit any other MAF than an uprated one from alive, as normal one can't cope with the air flow.
But check waste gate and ecu first.
Andy
Post #189683 29th Nov 2012 10:50pm
Welshsurferdude
Wales
Not by me, im not sure it goes well, i think its has a BAS at some point but I will eliminate stuff first.
bought a new injector harness as thats a service item anyway. Smile
if its none of the stuff above, then i will get a uprated maf from one of the forum sponsors 2011 Santorini Black USW XS.
Post #189690 29th Nov 2012 11:20pm
Page 2 of 2 <12
