![]() | Home > Technical > 2002 110 td5 strange hiccuping or slight hestigation? |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2529 ![]() ![]() |
Ok list of things to do tomorrow morning is to
Check ECU plug for oil Check turbo wastegate for freedom of movement Check fuel regulator for leaks, as it diesel will the leak show up easily? 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
Is yours remapped?.
Mine does this at very high revs if I fit any other MAF than an uprated one from alive, as normal one can't cope with the air flow. But check waste gate and ecu first. Andy |
Not by me, im not sure it goes well, i think its has a BAS at some point but I will eliminate stuff first.
bought a new injector harness as thats a service item anyway. ![]() if its none of the stuff above, then i will get a uprated maf from one of the forum sponsors 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
