Home > Technical > 2002 110 td5 strange hiccuping or slight hestigation?
Welshsurferdude
Wales
i drove my 110 td5 today, and i was in the mood for some flat out driving.
so i put pedal down on the slip road coming on to the m4 and when the revs got to 2500-3000 it started what seemed to be like gentle slow hiccuping, it only seeems to do it in high revs when accelertating hard and/or foot flat down maintaining mway speeds
any ideas what it might be? its got 155k on the clock.
Regards 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #189538 29th Nov 2012 5:14pm
SGH
Oil tracking into ecu down wiring loom had the same with my td5 110 only a speed.
Post #189547 29th Nov 2012 6:10pm
Welshsurferdude
Wales
Would the symptoms include slight over revving too as my mrs has reported that too. 2011 Santorini Black USW XS.
Post #189549 29th Nov 2012 6:18pm
Lou Sparts
Ditto the injector harness,take the red plug off the ecu under the drivers seat and check for oil contamination.If oil is present you need a new injector harness (and cam cover gasket) this is an easy diy fix,must be loads of threads on here ref changing it. 2005 Td5 90 XS
Steve
Post #189550 29th Nov 2012 6:20pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Yep.
Get a spray tin of electrical contact cleaner and have a go at the main red ECU plug and the one underneath the sound cover on the engine that connects the injector loom to the main harness.
Its worth factoring in a new injector harness every 60k miles or so. 2002 Defender 110 DC
Post #189555 29th Nov 2012 6:29pm
Welshsurferdude
Wales
Yep I looked through the threads
New injector loom ordered along with contact cleaner and a sandwich box to pop the ecu in to waterproof it! god knows when it was last done being 155k! 2011 Santorini Black USW XS.
Post #189561 29th Nov 2012 6:47pm
mk1collector
Sorry to hijack but with the looms are you best buying genuine or are the spurious ones of eBay ok?
Ray
Post #189565 29th Nov 2012 7:09pm
Lou Sparts
Quality is remembered long after the price is forgotten ! 2005 Td5 90 XS
Steve
Post #189566 29th Nov 2012 7:12pm
bob neville
I purchased mine, along with the cam cover gasket, from site sponsor Gary at Alive Tuning Thumbs Up
2013 Defender 90 CSW - sold
Post #189572 29th Nov 2012 7:29pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Keep an eye on the oil level too, if it increases, replace the injector seals and copper washers, using gen lr parts and pray you don't have a cracked head.
Just been thru this with our td5 and there was 5lts of diesel contaminating the oil in the engine block... Big Cry
Seals changed and fingers crossed no harm done
N.
Post #189591 29th Nov 2012 8:38pm
Porny
Site Sponsor
Do this test - it is the most likely cause Wink
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #189601 29th Nov 2012 8:59pm
excossack
How much effort is the right amount? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #189623 29th Nov 2012 9:37pm
Welshsurferdude
Wales
I got it off ebay yes, but it wasnt the cheapest! It had a LR part number on it which was the one I wanted.
Ill see what it looks like when it arrives, if not then Ill stick it back on ebay and get a genuine set from one of the forum sponsors. 2011 Santorini Black USW XS.
Post #189638 29th Nov 2012 9:52pm
Welshsurferdude
Wales
PS Porny Ill be testing that in the morning! 2011 Santorini Black USW XS.
Post #189639 29th Nov 2012 9:53pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
As per Ian's suggestion, sticking wastegate is usually has these symptoms at higher revs
For the over revving. Check you fuel regulator for leaks. In colder weather they can leak more and it can contaminate the clutch causing slip under load. Fix is to replace or re-seal regulator
An alternative to oil in loom issue is to clean ECU connectors and then fill with electrical grease petroleum jelly, then close. You then won't get any oil ingress again.
Steve
Post #189642 29th Nov 2012 9:54pm
