|  | Home > Maintenance & Modifications > Simple / cheap / discreet |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967    | Whats in there     | ||
|  19th Nov 2012 1:44pm |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489      | Don't tell him! He just wants to nick it!        | ||
|  19th Nov 2012 2:17pm |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265    |
 The keys  | ||
|  19th Nov 2012 2:32pm |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387    |  QRZ M8VPF | ||
|  19th Nov 2012 8:51pm |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478      |
    , is a very good idea could be worth putting one on the battery box try and slow theives down from getting in there  CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive | ||
|  19th Nov 2012 8:52pm |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265    | I don't need to be going either box all the time so it's a passive extra layer job.
 Done both sides, works really well so not a bad security mod for £5 and a bit of time but you have to be realistic if somebody has brought the tools to screwdriver the ignition that little lock isn't going to fox 'em   I need to come up with a bit of steel that secures the the opposite side to the lock down, currently you really wanted access you could bend the front corner up rather than slide out although putting the seat back with it bent up wouldn't be easy. | ||
|  19th Nov 2012 9:20pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | Forgive me going off topic a bit but didn't Series Land Rovers have a type of hasp catch that could have a padlock fitted? | ||
|  20th Nov 2012 12:09am |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029    |
 Not sure on your answer but the current Puma does and there is one in the picture above too! It's the clamp / hasp that holds the plate in place and has a hole on it if you look closely for a small lock once shut. Not ultra secure no but a PITA to come across to a potential thief. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ | ||
|  20th Nov 2012 12:20am |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | Yep I know what you mean, I have the same on my Td5. The things I was thinking of are a little more robust and consist of a hinged flap of steel on the removable cover that drops down to the front of the seat box, where the existing clip is found. On the flap there is a "keyhole" cut-out that a P shaped turnbuckle passes through that has to be turned uppermost. When it's closed the P turnbuckle drops down making a secure lock. The P clip has a hole in it that a padlock can pass through. | ||
|  20th Nov 2012 12:47am |
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677      |
 they did yes Steve | ||
|  20th Nov 2012 8:02am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      |
 Just visible here on the leading edge of the seatbox:   Click image to enlarge | ||
|  20th Nov 2012 12:49pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | Them be the kiddies! | ||
|  20th Nov 2012 4:52pm |
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677      | as can be seen the fuel tank changeover tap
 steve | ||
|  21st Nov 2012 9:55pm |
| SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675    | Another good thing to do is relocate your alarm horn and move OBDII connector to inside your locked under seat box. | ||
|  22nd Nov 2012 6:40pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
