![]() | Home > Maintenance & Modifications > Simple / cheap / discreet |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
Whats in there
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Don't tell him! He just wants to nick it!
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
The keys ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
I don't need to be going either box all the time so it's a passive extra layer job.
Done both sides, works really well so not a bad security mod for £5 and a bit of time but you have to be realistic if somebody has brought the tools to screwdriver the ignition that little lock isn't going to fox 'em ![]() I need to come up with a bit of steel that secures the the opposite side to the lock down, currently you really wanted access you could bend the front corner up rather than slide out although putting the seat back with it bent up wouldn't be easy. |
Forgive me going off topic a bit but didn't Series Land Rovers have a type of hasp catch that could have a padlock fitted?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20952 ![]() ![]() |
Not sure on your answer but the current Puma does and there is one in the picture above too! It's the clamp / hasp that holds the plate in place and has a hole on it if you look closely for a small lock once shut. Not ultra secure no but a PITA to come across to a potential thief. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Yep I know what you mean, I have the same on my Td5. The things I was thinking of are a little more robust and consist of a hinged flap of steel on the removable cover that drops down to the front of the seat box, where the existing clip is found. On the flap there is a "keyhole" cut-out that a P shaped turnbuckle passes through that has to be turned uppermost. When it's closed the P turnbuckle drops down making a secure lock. The P clip has a hole in it that a padlock can pass through.
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
they did yes Steve |
Just visible here on the leading edge of the seatbox: ![]() Click image to enlarge |
Them be the kiddies!
as can be seen the fuel tank changeover tap
steve |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Another good thing to do is relocate your alarm horn and move OBDII connector to inside your locked under seat box.
