Home > Maintenance & Modifications > Simple / cheap / discreet
Tiger
Just added a twist hasp lock to the seat box. Seems to work okay, quite aware it won't doo too much but better than nothing and relatively cheap.
Post #186299 19th Nov 2012 12:40pm
ibexman
Whats in there Whistle Whistle
Post #186301 19th Nov 2012 12:44pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Don't tell him! He just wants to nick it! Wink Wink Laughing
Post #186303 19th Nov 2012 1:17pm
Tiger
The keys Big Cry
Post #186306 19th Nov 2012 1:32pm
Rolling with laughter QRZ M8VPF
Post #186429 19th Nov 2012 7:51pm
Killer90
Site Sponsor
Tiger wrote:
The keys Big Cry
Rolling with laughter Rolling with laughter , is a very good idea could be worth putting one on the battery box try and slow theives down from getting in there Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #186431 19th Nov 2012 7:52pm
Tiger
I don't need to be going either box all the time so it's a passive extra layer job.
Done both sides, works really well so not a bad security mod for £5 and a bit of time but you have to be realistic if somebody has brought the tools to screwdriver the ignition that little lock isn't going to fox 'em Mad
I need to come up with a bit of steel that secures the the opposite side to the lock down, currently you really wanted access you could bend the front corner up rather than slide out although putting the seat back with it bent up wouldn't be easy.
Post #186441 19th Nov 2012 8:20pm
JWL
Forgive me going off topic a bit but didn't Series Land Rovers have a type of hasp catch that could have a padlock fitted?
Post #186519 19th Nov 2012 11:09pm
Not sure on your answer but the current Puma does and there is one in the picture above too! It's the clamp / hasp that holds the plate in place and has a hole on it if you look closely for a small lock once shut. Not ultra secure no but a PITA to come across to a potential thief. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #186520 19th Nov 2012 11:20pm
JWL
Yep I know what you mean, I have the same on my Td5. The things I was thinking of are a little more robust and consist of a hinged flap of steel on the removable cover that drops down to the front of the seat box, where the existing clip is found. On the flap there is a "keyhole" cut-out that a P shaped turnbuckle passes through that has to be turned uppermost. When it's closed the P turnbuckle drops down making a secure lock. The P clip has a hole in it that a padlock can pass through.
Post #186531 19th Nov 2012 11:47pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
they did yes
Steve
Post #186541 20th Nov 2012 7:02am
borderterrier wrote:
they did yes
Steve
Just visible here on the leading edge of the seatbox:
Post #186570 20th Nov 2012 11:49am
JWL
Them be the kiddies!
Post #186622 20th Nov 2012 3:52pm
borderterrier
as can be seen the fuel tank changeover tap
steve
Post #187016 21st Nov 2012 8:55pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Another good thing to do is relocate your alarm horn and move OBDII connector to inside your locked under seat box.
Post #187238 22nd Nov 2012 5:40pm
