Home > Maintenance & Modifications > Nakatanenga Stainless Bolt Kits
Page 4 of 5 <12345>
landy andy
Thanks Thumbs Up
So I would be after a VAST 110SW kit for a 110 double cab. Is that correct?
Andy
Post #279170 3rd Nov 2013 7:42pm
No because the SW comes with rear door hinge bolts that you won't need. I would contact them and get what you want specific or buy the items you want individually / request a price.
* Don't quote me exactly on what exactly the kit contains as I haven't looked into it. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #279175 3rd Nov 2013 7:57pm
If Nak could supply in parts that you can buy door bolts or similar individually as Stigs do then I'd go for Nak. But I realise their issue of shipping over here does that in. Having said all this with various kits, many of us have bolt on extras which may require extra bolts anyway.
Plenty to think about. ____\We|Will|Win/___
Post #279177 3rd Nov 2013 8:02pm
leeds
Correct.
VAST 110SW
Nakatanenga 4x4 Equipment - Products » Attachments & Couplings » Screws » Stainless steel screw kit for Land Rover Defender 110 SW / 110 CC / 130 CC
EXCLUSIVE NOW form for our manufactured GENUINE Land Rover.
, the screws have the same heads as the original screws on the Defender! set includes a total of approximately 430 parts. By this set can all externally visible screws on the vehicle with high-quality, stainless steel V2A stainless steel screws be replaced. Fits all years - TDi, TD5, TD4 2.4 TD4 2.2 The side door and rear door hinge screws, and the screws on the body mount at the rear are made ​​specifically for us and comply in the form of the original screws (Torx tool holder). , added with even specially manufactured for us bonnets buffer screws pack included. , the screw sets are clearly for each part of the vehicle in 10 bags packed: - Rear Door Hinge - body mount rear - front grille - loading bar + reflectors - bonnet hinges - crossmember rear - Spare wheel - Eyebrows + fender covers - side door hinges - Door sill inside + A-pillar and 2 buffer screws + 1 tube of anti-seize . A simple installation is possible even for car lay . Additionally, you receive from us a tube of anti-seize paste for screws Please note: This set includes not the stainless steel hinge pins for the vents
OR
VAST 4DR
Stainless steel door hinge screws kit for Land Rover Defender 110 SW/130CC
NOW EXCLUSIVE made ​​for us in the form ORIGINAL Land Rover.
Fits all years - TDi, TD5, TD4 2.4, 2.2 TD4
Full Screw Set for 4 doors and rear door, stainless steel V2A for Defender 110 SW/130CC, including anti-seize paste.
So these sets are suitable for a 110 SW or a 130 CC (Crew cab)
Brendan
Post #279181 3rd Nov 2013 8:17pm
For any of you that unfortunately missed out on getting one of these bolt kits before Christmas I can confirm that it is really good and well worth still getting.
Like for like swapping of each bolt all in various packs and includes the "special paste"
Time consuming job which I like but the results are great and really comprehensive.
Only slight difficulty is working out what goes where! Most of it is self explanatory as you work through it but at some point I might have to ask what some bits are for. ____\We|Will|Win/___
Post #293680 28th Dec 2013 5:48pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I am struggling to wait to get mine Tbh. With no definitive date, my build needs to move forward, I will have to check out the alternatives. V8 90...WIP
Post #293817 29th Dec 2013 2:08am
leeds
The bolt kits are back in stock in Germany.
They are being despatched to us on the 6th January when we are back in the UK. They should be with us on the 8th.
The Nakatanenga kits are the only ones with the GENUINE heads on the door bolts and is the most comprehensive kits available.
Brendan
Post #293818 29th Dec 2013 2:15am
Paul - Stick to the Nak kit mate, it's really good! Just unfortunate that the stock ran out when it did.
Brendan - Fitted most of mine but getting down to some of the bolts and screws I'm not sure on.
If I post up some photos could you tell me what goes where?
There is some allen head screws I've got there that I have no clue on, I have a suspicion it might be for the SW air con grille which I don't have.
Could be wrong though. ____\We|Will|Win/___
Post #293885 29th Dec 2013 2:16pm
Does anyone know what these are for?
As I mentioned above I'm thinking XS air con grille but could be wrong, I don't have air con anyway but interested to know.
Anyone?
P.S. Sorry about photo quality was a bit dark, they are allen headed too. ____\We|Will|Win/___
Post #294258 30th Dec 2013 5:16pm
They're not for an air con grill. That doesn't use any nuts and bolts.
Something to do with the rear seats, maybe? Darren
Post #294267 30th Dec 2013 5:36pm
Maybe, I can't work out what they are for. Confused They are in the pack regarding the grille / front area ____\We|Will|Win/___
Post #294274 30th Dec 2013 5:54pm
Perhaps they're for something behind the grill - possibly the slam panel stays or rad supports. Darren
Post #294338 30th Dec 2013 9:39pm
Could be, leaving them for now and continuing the rest.
Very pleased with them so far.
Front floor pan bolts and A pillar screws next. ____\We|Will|Win/___
Post #294343 30th Dec 2013 9:53pm
ericvv
Steve, why not sending a PM to nakatanenga? They are a site sponsor here, and often are posting themselves under that very nakatanenga username. Think many people here will be interested in their answer and clarification. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #294354 30th Dec 2013 10:05pm
nakatanenga
Germany
These are for the front grille if you like them.
For the aircon grille are different options:
reuse the original plasic thingies
use the supplied Alan bolts
We do not do different kits for different model years, we just add as many variations as possible, so that means you will have spare bolts.......which is always good if you are a Defender owner Wink WANTED:
SII or SIII in max 1.5k
Post #294538 31st Dec 2013 12:42pm
Page 4 of 5 <12345>
