![]() | Home > Maintenance & Modifications > Nakatanenga Stainless Bolt Kits |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
Thanks
![]() So I would be after a VAST 110SW kit for a 110 double cab. Is that correct? Andy |
If Nak could supply in parts that you can buy door bolts or similar individually as Stigs do then I'd go for Nak. But I realise their issue of shipping over here does that in. Having said all this with various kits, many of us have bolt on extras which may require extra bolts anyway.
Plenty to think about. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Correct.
VAST 110SW Nakatanenga 4x4 Equipment - Products » Attachments & Couplings » Screws » Stainless steel screw kit for Land Rover Defender 110 SW / 110 CC / 130 CC Stainless steel screw kit for Land Rover Defender 110 SW / 110 CC / 130 CC EXCLUSIVE NOW form for our manufactured GENUINE Land Rover. , the screws have the same heads as the original screws on the Defender! set includes a total of approximately 430 parts. By this set can all externally visible screws on the vehicle with high-quality, stainless steel V2A stainless steel screws be replaced. Fits all years - TDi, TD5, TD4 2.4 TD4 2.2 The side door and rear door hinge screws, and the screws on the body mount at the rear are made specifically for us and comply in the form of the original screws (Torx tool holder). , added with even specially manufactured for us bonnets buffer screws pack included. , the screw sets are clearly for each part of the vehicle in 10 bags packed: - Rear Door Hinge - body mount rear - front grille - loading bar + reflectors - bonnet hinges - crossmember rear - Spare wheel - Eyebrows + fender covers - side door hinges - Door sill inside + A-pillar and 2 buffer screws + 1 tube of anti-seize . A simple installation is possible even for car lay . Additionally, you receive from us a tube of anti-seize paste for screws Please note: This set includes not the stainless steel hinge pins for the vents OR VAST 4DR Stainless steel door hinge screws kit for Land Rover Defender 110 SW/130CC NOW EXCLUSIVE made for us in the form ORIGINAL Land Rover. screws have the same heads as the original screws on the Defender! Fits all years - TDi, TD5, TD4 2.4, 2.2 TD4 Full Screw Set for 4 doors and rear door, stainless steel V2A for Defender 110 SW/130CC, including anti-seize paste. comply in the form of the original screws (Torx tool holder). , added with even specially manufactured for us bonnets buffer screws pack included. , the screw sets are clearly for each part of the vehicle in 10 bags packed: - Rear Door Hinge - body mount rear - front grille - loading bar + reflectors - bonnet hinges - crossmember rear - Spare wheel - Eyebrows + fender covers - side door hinges - Door sill inside + A-pillar and 2 buffer screws + 1 tube of anti-seize . A simple installation is possible even for car lay . Additionally, you receive from us a tube of anti-seize paste for screws Please note: This set includes not the stainless steel hinge pins for the vents So these sets are suitable for a 110 SW or a 130 CC (Crew cab) Brendan |
For any of you that unfortunately missed out on getting one of these bolt kits before Christmas I can confirm that it is really good and well worth still getting.
Like for like swapping of each bolt all in various packs and includes the "special paste" Time consuming job which I like but the results are great and really comprehensive. Only slight difficulty is working out what goes where! Most of it is self explanatory as you work through it but at some point I might have to ask what some bits are for. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
I am struggling to wait to get mine Tbh. With no definitive date, my build needs to move forward, I will have to check out the alternatives. V8 90...WIP
The bolt kits are back in stock in Germany.
They are being despatched to us on the 6th January when we are back in the UK. They should be with us on the 8th. The Nakatanenga kits are the only ones with the GENUINE heads on the door bolts and is the most comprehensive kits available. Brendan |
Paul - Stick to the Nak kit mate, it's really good! Just unfortunate that the stock ran out when it did.
Brendan - Fitted most of mine but getting down to some of the bolts and screws I'm not sure on. If I post up some photos could you tell me what goes where? There is some allen head screws I've got there that I have no clue on, I have a suspicion it might be for the SW air con grille which I don't have. Could be wrong though. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Does anyone know what these are for?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge As I mentioned above I'm thinking XS air con grille but could be wrong, I don't have air con anyway but interested to know. Anyone? P.S. Sorry about photo quality was a bit dark, they are allen headed too. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
They're not for an air con grill. That doesn't use any nuts and bolts.
Something to do with the rear seats, maybe? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Maybe, I can't work out what they are for.
![]() ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Perhaps they're for something behind the grill - possibly the slam panel stays or rad supports. Darren
Could be, leaving them for now and continuing the rest.
Very pleased with them so far. Front floor pan bolts and A pillar screws next. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Steve, why not sending a PM to nakatanenga? They are a site sponsor here, and often are posting themselves under that very nakatanenga username. Think many people here will be interested in their answer and clarification. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
These are for the front grille if you like them.
For the aircon grille are different options: reuse the original plasic thingies use the supplied Alan bolts We do not do different kits for different model years, we just add as many variations as possible, so that means you will have spare bolts.......which is always good if you are a Defender owner ![]() SII or SIII in max 1.5k |
