Home > Maintenance & Modifications > Wolf Air Intake Grill
Anyone fitted one of these to their motor?
Any genuine benefits or just a bit of bling?
Post #179875 28th Oct 2012 9:08pm
IF you fit them as a pair, along with the internal pipework, then yes, some advantage as you can list over and cover one wing with water, but the engine will still be able to breathe through the other side.
Although IMO far easier to add a RAI.... just as the MoD did to a lot of the vehicles, removing one (or both) of these wolf intakes and just having a raised intake.... although I suspect this was more for dust intake rather than deep water wading.
Post #179902 28th Oct 2012 9:59pm
Glynparry25
The whole idea of the above was for the prevention of water 'splashes' into the intake pipes. Completely pointless paying for it unless it is for looks.
Glyn Dog Sheep
Post #179961 29th Oct 2012 12:12am
ibexman
It gives you around 6 inches more wading depth too supposedly
Post #180034 29th Oct 2012 11:44am
How does that work?
Post #180256 30th Oct 2012 7:28am
ibexman
Theres a sort of bulkhead inside which is almost at the top of the grill if that helps
Post #180320 30th Oct 2012 12:13pm
thanks Thumbs Up
Post #180438 30th Oct 2012 6:51pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
As much use as a button on a sock Smile
Post #180439 30th Oct 2012 6:53pm
