![]() | Home > Maintenance & Modifications > Anderson connector on seatbox |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Don't take the cables through the seat box! Problem solved
Click image to enlarge Fixed Anderson protruding through seat box fasten to top of seat box. Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
That reminds me, Snakes on a plane is on tv later
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8481
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Here you say different
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
However system does work! Two winches, Anderson connector, hf radio etc. Maybe not tidest but one which works! Brendan |
| sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455
I've just ordered some along with other bits from Tim
I'm going to mount mine on the seat box front pointing up (must remember to put cover on) so I can plug in with the door shut and pass leads out window because when I've tried to jump start things using my traffic van which has a passenger footwell positioned battery I can't get close enought to cars with the door open sometimes Think I'm going to run cables in some 25mm conduit into rubber shroud then into plug But just a thought remember to put spacers between box and plug if you've got carpet as when you tighten plug back it will sink into carpet and might stop the trailing end fitting It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
When less is more
Click image to enlarge We tend to advocate the use of bus bars which makes the joing of multiple large cables easier and neater. I have some pictures if anyone wants to see them. |
We also do some nice mountings to go on the genuine LR adjustable tow bar so you can mounty an Anderson on the rear
Click image to enlarge Last edited by mobilecentre on 16th Oct 2012 8:53am. Edited 1 time in total |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Tim
Got any pictures of the pole type jump start connectors installed as I am thinking of these for my 110 Simon 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Simon
I do not have any pictures but I might stick a set in mine in a few weeks as I have not drilled any holes in it for a while I will post some pics if I do. Tim |
I might stick a set in mine in a few weeks as I have not drilled any holes in it for a while:whistle:
I feel like that a times Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Im filling all the holes up
Click image to enlarge |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
Someone with slight OCD issues must have spent way to long doing all of that install.... Apart from appearance, if everything is neatly laid out it makes life much easier if you ever need to do any fault finding, or adding additional circuits components.... and it looks a lot more professional. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389
........i used to drive thru Spaghetti Jct everyday.. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
