Home > Maintenance & Modifications > Anderson connector on seatbox
ibexman
I want to fit my anderson connector to the seatbox has any one found a neat solution for the battery cables coming through the seat box pics please cheers chris
Post #176062 15th Oct 2012 7:24pm
leeds
Don't take the cables through the seat box! Problem solved Razz
Fixed Anderson protruding through seat box fasten to top of seat box. Thumbs Up
Brendan
Post #176072 15th Oct 2012 7:48pm
That reminds me, Snakes on a plane is on tv later Whistle QRZ M8VPF
Post #176076 15th Oct 2012 7:52pm
jst
Rolling with laughter Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176079 15th Oct 2012 7:58pm
VeeTee
Netherlands
Here you say different Laughing
leeds wrote:
Typical 12 volt sockets are rate at 16-20 amps Many 12v compressors are fused at 30-40 amps so do not really suitable for 12v sockets.
Small Anderson connectors are rated at 50 amps, standard one are rated at 175 amps. These are continuous rated but can carry much higher currents for short periods of time.
They can be located on the front of the battery box like this.
Doing it this way it is important to ensure cables going into the battery box is well grometted!
Alternative is for Anderson connector to poke out of battery box like this
If you use 175 amp Anderson connectors apart from compressor you can use jump leads, 12volt drills etc.
Brendan
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #176081 15th Oct 2012 8:01pm
leeds
Thumbs Up
Thumbs Up Rolling with laughter
However system does work! Two winches, Anderson connector, hf radio etc.
Maybe not tidest but one which works!
Brendan
Post #176082 15th Oct 2012 8:01pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I've just ordered some along with other bits from Tim
I'm going to mount mine on the seat box front pointing up (must remember to put cover on) so I can plug in with the door shut and pass leads out window because when I've tried to jump start things using my traffic van which has a passenger footwell positioned battery I can't get close enought to cars with the door open sometimes
Think I'm going to run cables in some 25mm conduit into rubber shroud then into plug
But just a thought remember to put spacers between box and plug if you've got carpet as when you tighten plug back it will sink into carpet and might stop the trailing end fitting It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #176105 15th Oct 2012 8:39pm
mobilecentre
When less is more
We tend to advocate the use of bus bars which makes the joing of multiple large cables easier and neater.
I have some pictures if anyone wants to see them.
Post #176161 16th Oct 2012 7:40am
mobilecentre
We also do some nice mountings to go on the genuine LR adjustable tow bar so you can mounty an Anderson on the rear
Post #176167 16th Oct 2012 7:49am
SGH
Tim
Got any pictures of the pole type jump start connectors installed as I am thinking of these for my 110
Simon 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #176169 16th Oct 2012 7:52am
mobilecentre
Simon
I do not have any pictures but I might stick a set in mine in a few weeks as I have not drilled any holes in it for a while Whistle
I will post some pics if I do. Thumbs Up
Tim
Post #176174 16th Oct 2012 7:58am
SGH
I might stick a set in mine in a few weeks as I have not drilled any holes in it for a while:whistle:
I feel like that a times Rolling with laughter 993 Varioram - Guards Red
Post #176179 16th Oct 2012 8:06am
Im filling all the holes up Big Cry
Post #176181 16th Oct 2012 8:34am
Porny
Site Sponsor
mobilecentre wrote:
When less is more
Someone with slight OCD issues must have spent way to long doing all of that install.... Wink
Apart from appearance, if everything is neatly laid out it makes life much easier if you ever need to do any fault finding, or adding additional circuits components.... and it looks a lot more professional.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #176223 16th Oct 2012 11:22am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Brendan
........i used to drive thru Spaghetti Jct everyday..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Putting Dreams on Drives at JLR Solihull..
Post #176228 16th Oct 2012 11:54am
