Home > Maintenance & Modifications > Anderson connector on seatbox
Page 2 of 2 <12
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
photo shows location of my two anderson connectors - one for a set of jump leads and one for small tools. The cables passing through the seat box are ptotected by heat shrink and by rubber grommet
Post #176358 16th Oct 2012 9:03pm
leeds
Yes I will admit that the red 110 battery box is not the neatest, it has evolved over time. However it was not built as a show vehicle but as a overland vehicle and it has proved its worth in the field so to speak.
A quick word of caution, please note that different colours of Anderson connectors will not readily match with each other.
Brendan
Post #176360 16th Oct 2012 9:13pm
mobilecentre
The use of bus bars prevents the dead octopuses in the seat boxes.
On mine I have front and rear jump leads, blue sea fuse box then additional power running out to another Blue sea fuse box with all the earths also returning back to bus bars. Both batteries are also fused.
Another word of warning on Andersons is they are coloured to denote application voltage with yellow being 12V,
Post #176392 16th Oct 2012 10:49pm
udderlyoffroad
Laughing
Where have you positioned your octupus-traps (busbars) Tim? Any chance of some piccies?
I too plan to have Andersons mounted front rear and centre as my seats will not be OE and therefore the bases will not be removable.
Matt Real trucks don't have spark plugs
Post #176845 18th Oct 2012 4:29pm
mobilecentre
Left side of the seat box looking in from the door
Right side
Post #176848 18th Oct 2012 4:51pm
udderlyoffroad
Awesome, thanks Tim. Will try to make my installation as neat as yours! Real trucks don't have spark plugs
Post #176872 18th Oct 2012 7:11pm
mobilecentre
We carry the bus bars, fuse holders, batteries, Blue Sea relays, twin battery trays etc all in stock if you need anything Thumbs Up
Post #176876 18th Oct 2012 7:17pm
excossack
Good idea on the bus bars, but I would like some kind over cover over the top of the positive connectors just in case.. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #176904 18th Oct 2012 8:27pm
mobilecentre
You mean one of these
Thumbs Up
Post #176907 18th Oct 2012 8:32pm
excossack
Yup those are the puppies. Very Happy 1999 Defender TD5 110
Regards
John M0VAZ
Post #176908 18th Oct 2012 8:34pm
Page 2 of 2 <12
