![]() | Home > Maintenance & Modifications > Anderson connector on seatbox |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Yes I will admit that the red 110 battery box is not the neatest, it has evolved over time. However it was not built as a show vehicle but as a overland vehicle and it has proved its worth in the field so to speak.
A quick word of caution, please note that different colours of Anderson connectors will not readily match with each other. Brendan |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
The use of bus bars prevents the dead octopuses in the seat boxes.
On mine I have front and rear jump leads, blue sea fuse box then additional power running out to another Blue sea fuse box with all the earths also returning back to bus bars. Both batteries are also fused. Another word of warning on Andersons is they are coloured to denote application voltage with yellow being 12V, |
| udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124
Where have you positioned your octupus-traps (busbars) Tim? Any chance of some piccies? I too plan to have Andersons mounted front rear and centre as my seats will not be OE and therefore the bases will not be removable. Matt Real trucks don't have spark plugs |
Left side of the seat box looking in from the door
Click image to enlarge Right side Click image to enlarge
Awesome, thanks Tim. Will try to make my installation as neat as yours! Real trucks don't have spark plugs
We carry the bus bars, fuse holders, batteries, Blue Sea relays, twin battery trays etc all in stock if you need anything
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Good idea on the bus bars, but I would like some kind over cover over the top of the positive connectors just in case.. 1999 Defender TD5 110
You mean one of these
Yup those are the puppies.
