Home > Puma (Tdci) > Windscreen replacement
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
I had a replacement screen a couple of weeks ago after a bolt was flicked up on the motorway in Denmark. Auto glass replaced it, but it leaked immediately. Took the car back, they found nothing, said it was the foam filler between the windscreen and the bulkhead. I pointed out it never leaked before, it was literally like putting a hosepipe in the footwell.
This weekend it's back at autoglass after I found the leak with my hosepipe. Bottom of the windscreen, by the heater conections on the left and right. I then went to the land rover garage to have a look at the new x tech. I had a look at the windscreen rubber and it looked as if it had a double seal, mine has literally about 1.5mm of overhang Confused Round the windscreen. Autoglass remain adamant it's a landrover replacement.
Does anyone have any idea's. does the original have double seal? I'm now two weekends without my car Evil or Very Mad
Post #175499 13th Oct 2012 9:01pm
ickle
I swapped the heated screen & rubber out of my 100" into th ePuma a couple of weeks ago (was used for less than a year before I put it in the garage when I bought the Puma), and I'm sure both rubbers have a 'double lip' around the outer edge against the body.
I sealed the new one into the Puma & all ok, I ran out of time on the 100" and it leaked like a pig until I sealed it.
Best of luck.
Keith
Post #175503 13th Oct 2012 9:12pm
K9F
From another thread....follow the link.... Thumbs Up
K9F wrote:
The issue of possible windscreen surround corrosion with ingress of dirt and crud was highlighted by me nearly three years ago in the thread below. I and Fekete had long running issues with water ingress which were finally resolved with a windscreen out and sealing the seal. With all the crud that sits in the channe under the seall it is no wonder at all the corrosion shown in the pictures. I would imagine there will be many more cases of this to come in the next year or so.....
http://www.defender2.net/forum/topic2126.html
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #175604 14th Oct 2012 10:09am
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
Just had replacement screen in my puma...heated as well Smile
Post #175924 15th Oct 2012 1:05pm
Who fitted it and does it leak?
Post #175944 15th Oct 2012 1:51pm
ClaireWright
My hubby fitted it and no it doesn't leak....he's been in automotive glazing for years
Post #175956 15th Oct 2012 3:42pm
Ah, trade connections!
The reason I ask is that I have a heated screen stashed in the house, and an unheated screen with several stone-chips and cracks in the Defender, and need to get them swapped. I am trying to figure out who best to get to do it, bearing in mind the tales of leaks etc.
Best local quote sofar has been £90 from Gavin (of special resin fame).
I was thinking of doing it myself as I have done quite a few traditional flat class rubber-sealed windows in the past, but it is a rather expensive piece of glass to risk if it goes wrong.
Post #175959 15th Oct 2012 4:03pm
I asked Autoglass for a price to swap a read heated screen recently and they quoted me £120 Shocked Darren
Post #175993 15th Oct 2012 6:06pm
Higgers
Supposedly fixed today, we'll see if my feet remain dry Laughing
Post #175995 15th Oct 2012 6:07pm
ClaireWright
Shame your in Dorset and not nearer to midlands,we could have replaced it for you Smile
Post #175997 15th Oct 2012 6:16pm
It is a shame! Would have been great to have a Landrover glass specialist do it!
Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price?
Post #176095 15th Oct 2012 9:18pm
ClaireWright
You need to seal wear tags are on new screens common leak
[quote="blackwolf"][quote="ClaireWright"]
Shame your in Dorset and not nearer to midlands,we could have replaced it for you :-)[/quote]
Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price?[/quote]
Post #179136 26th Oct 2012 10:52am
ClaireWright
When replacing heated screen you have to seal rubber wear tags are. Even if you fit new rubber because we're tags are soldered to screen a small piece of glass is removed to solder tag to buz bar that's why they can leak water passes down and back up into car were tags are as there's a hole there :thumbsup:
Post #179138 26th Oct 2012 11:01am
K9F
Blackwolf, sorry for the delay must have missed your post....
Autoglass, behind Castlepoint.....Send me a 'pm' and if convenient we'll hook up for coffee and a chat....Sorted out my water ingress woes...
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179139 26th Oct 2012 11:02am
JSG
What are wear tags Claire and where are they? I've not noticed anything additional on my screen other than the 12v connections? John
2011 Tdci 110 CSW XS
Post #179186 26th Oct 2012 3:51pm
