![]() | Home > Puma (Tdci) > Windscreen replacement |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
I swapped the heated screen & rubber out of my 100" into th ePuma a couple of weeks ago (was used for less than a year before I put it in the garage when I bought the Puma), and I'm sure both rubbers have a 'double lip' around the outer edge against the body.
I sealed the new one into the Puma & all ok, I ran out of time on the 100" and it leaked like a pig until I sealed it. Best of luck. Keith |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
From another thread....follow the link....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609
Just had replacement screen in my puma...heated as well
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
Who fitted it and does it leak? |
My hubby fitted it and no it doesn't leak....he's been in automotive glazing for years
Ah, trade connections!
The reason I ask is that I have a heated screen stashed in the house, and an unheated screen with several stone-chips and cracks in the Defender, and need to get them swapped. I am trying to figure out who best to get to do it, bearing in mind the tales of leaks etc. Best local quote sofar has been £90 from Gavin (of special resin fame). I was thinking of doing it myself as I have done quite a few traditional flat class rubber-sealed windows in the past, but it is a rather expensive piece of glass to risk if it goes wrong. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I asked Autoglass for a price to swap a read heated screen recently and they quoted me £120
| Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672
Supposedly fixed today, we'll see if my feet remain dry
Shame your in Dorset and not nearer to midlands,we could have replaced it for you |
It is a shame! Would have been great to have a Landrover glass specialist do it! Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price? |
[quote="blackwolf"][quote="ClaireWright"]
Shame your in Dorset and not nearer to midlands,we could have replaced it for you :-)[/quote] It is a shame! Would have been great to have a Landrover glass specialist do it! Can anyone recommend a windscreen fitter in the Poole/Blandford area of Dorset who can do a good leak-free job on a Defender at a sensible price?[/quote] |
When replacing heated screen you have to seal rubber wear tags are. Even if you fit new rubber because we're tags are soldered to screen a small piece of glass is removed to solder tag to buz bar that's why they can leak water passes down and back up into car were tags are as there's a hole there :thumbsup:
Blackwolf, sorry for the delay must have missed your post....
Autoglass, behind Castlepoint.....Send me a 'pm' and if convenient we'll hook up for coffee and a chat....Sorted out my water ingress woes... Treat every day as if it is your last....one day you will be right!! |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
What are wear tags Claire and where are they? I've not noticed anything additional on my screen other than the 12v connections? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| All times are GMT |
