Home > Td5 > TD5 fuel pump relay |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Thought it should be yellow and under the driver's seat.
(Second from rear.) |
7th Oct 2012 1:21am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5738 |
On mine the green relay does stop the fuel pump from working. The diagram on the panel shows a fuel pump symbol. I wonder what the 3 under the seat do then ? More investigation needed.
Thanks Laurie. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
7th Oct 2012 7:29pm |
JokeSparrow Member Since: 25 Nov 2011 Location: Friesland Posts: 4 |
Hi!
If there are 5 relays under your seat it is a car with Aircon and ABS. From back to front: 1. Coolingvan (Aircon?) 2. Aircon clutch 3. Glowplug relay 4. ABS Pump 5. Main Relay Main relay and green pump relay may cause starting problems. Excuse may simple description. Joke Sparrow from Germany ... there's no better way to drive! |
21st Oct 2012 5:47pm |
No AirCon and no ABS... So that leaves me with relay 3 and 5 1999 Defender TD5 110
21st Oct 2012 6:33pm |
I have a TD5 XS and the second relay from the rear (yellow) is the fuel pump.
21st Oct 2012 11:59pm |
Interesting...I will have to do some investigation in the relays under my seat. Mine is a Jan 1999 model I wondering if things changed later on? 1999 Defender TD5 110
22nd Oct 2012 8:26am |
Mine's 2005
22nd Oct 2012 10:10am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
2002MY different layout n different relay positions. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
24th Oct 2012 4:34pm |
Hi!
Had to work for a Fee days. Check the connector /female connector of the relays. Also ist is possible to open the relay with a small screwdriver. Maybe it smells burned. Sometimes you can see if it is. JokeSparrow ... there's no better way to drive! |
24th Oct 2012 8:56pm |
Only two relays under the drivers seat., Yellow and Black 1999 Defender TD5 110
4th Nov 2012 11:57am |
Ok.
Then your Car has no Aircondition. JokeSparrow ... there's no better way to drive! |
6th Nov 2012 2:21pm |
My fuelpump relay's yellow.
6th Nov 2012 2:24pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
OFF TOPIC! Friesland is not in Germany, I know this because I have completed the Elfsteden Rijwieltocht 5 times now |
6th Nov 2012 2:57pm |
Hey you!
Friesland is a county in Niedersachsen. My license plate starts with FRI- xx xxx. So there is another Friesland in the netherlands. JokeSparrow ... there's no better way to drive! |
6th Nov 2012 10:34pm |
