Home > Td5 > TD5 fuel pump relay
excossack
TD5 fuel pump relay
Should the green fuel pump relay in the fuse box by the gearstick be warm ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #173550 6th Oct 2012 12:31pm
Laurie
Thought it should be yellow and under the driver's seat.
(Second from rear.)
Post #173681 7th Oct 2012 1:21am
excossack
On mine the green relay does stop the fuel pump from working. The diagram on the panel shows a fuel pump symbol. I wonder what the 3 under the seat do then ? More investigation needed.
Thanks Laurie. 1999 Defender TD5 110
Regards
John M0VAZ
Post #173817 7th Oct 2012 7:29pm
JokeSparrow
Germany 1999 Defender 110 Td5 SW Epsom Green
Hi!
If there are 5 relays under your seat it is a car with Aircon and ABS.
From back to front:
1. Coolingvan (Aircon?)
2. Aircon clutch
3. Glowplug relay
4. ABS Pump
5. Main Relay
Main relay and green pump relay may cause starting problems.
Excuse may simple description.
Joke Sparrow
from Germany ... there's no better way to drive!
Post #177715 21st Oct 2012 5:47pm
excossack
No AirCon and no ABS... So that leaves me with relay 3 and 5 1999 Defender TD5 110
Regards
John M0VAZ
Post #177739 21st Oct 2012 6:33pm
Laurie
I have a TD5 XS and the second relay from the rear (yellow) is the fuel pump.
Post #177868 21st Oct 2012 11:59pm
excossack
Interesting...I will have to do some investigation in the relays under my seat. Mine is a Jan 1999 model I wondering if things changed later on? 1999 Defender TD5 110
Regards
John M0VAZ
Post #177883 22nd Oct 2012 8:26am
Laurie
Mine's 2005
Post #177906 22nd Oct 2012 10:10am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
2002MY different layout n different relay positions. The defender has migrated, leaving the owner behind.
Post #178641 24th Oct 2012 4:34pm
JokeSparrow
Hi!
Had to work for a Fee days.
Check the connector /female connector of the relays.
Also ist is possible to open the relay with a small screwdriver. Maybe it smells burned.
Sometimes you can see if it is.
JokeSparrow ... there's no better way to drive!
Post #178748 24th Oct 2012 8:56pm
excossack
Only two relays under the drivers seat., Yellow and Black 1999 Defender TD5 110
Regards
John M0VAZ
Post #181922 4th Nov 2012 11:57am
JokeSparrow
Ok.
Then your Car has no Aircondition.
Post #182562 6th Nov 2012 2:21pm
Laurie
My fuelpump relay's yellow.
Post #182565 6th Nov 2012 2:24pm
Tiger
Quote:
JokeSparrow
OFF TOPIC!
Friesland is not in Germany, I know this because I have completed the Elfsteden Rijwieltocht 5 times now Smile
Post #182579 6th Nov 2012 2:57pm
JokeSparrow
Hey you!
Friesland is a county in Niedersachsen.
My license plate starts with FRI- xx xxx.
So there is another Friesland in the netherlands.
Post #182732 6th Nov 2012 10:34pm
