![]() | Home > Td5 > TD5 fuel pump relay |
Thought it should be yellow and under the driver's seat.
(Second from rear.) ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
On mine the green relay does stop the fuel pump from working. The diagram on the panel shows a fuel pump symbol. I wonder what the 3 under the seat do then ? More investigation needed.
Thanks Laurie. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
JokeSparrow Member Since: 25 Nov 2011 Location: Friesland Posts: 4 ![]() ![]() ![]() |
Hi!
If there are 5 relays under your seat it is a car with Aircon and ABS. From back to front: 1. Coolingvan (Aircon?) 2. Aircon clutch 3. Glowplug relay 4. ABS Pump 5. Main Relay Main relay and green pump relay may cause starting problems. Excuse may simple description. Joke Sparrow from Germany ... there's no better way to drive! |
No AirCon and no ABS... So that leaves me with relay 3 and 5 1999 Defender TD5 110
I have a TD5 XS and the second relay from the rear (yellow) is the fuel pump.
Interesting...I will have to do some investigation in the relays under my seat. Mine is a Jan 1999 model I wondering if things changed later on? 1999 Defender TD5 110
Mine's 2005
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
2002MY different layout n different relay positions. The defender has migrated, leaving the owner behind.
Hi!
Had to work for a Fee days. Check the connector /female connector of the relays. Also ist is possible to open the relay with a small screwdriver. Maybe it smells burned. Sometimes you can see if it is. JokeSparrow ... there's no better way to drive! |
Only two relays under the drivers seat., Yellow and Black 1999 Defender TD5 110
Ok.
Then your Car has no Aircondition. JokeSparrow ... there's no better way to drive! |
My fuelpump relay's yellow.
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
OFF TOPIC! Friesland is not in Germany, I know this because I have completed the Elfsteden Rijwieltocht 5 times now ![]() |
Hey you!
Friesland is a county in Niedersachsen. My license plate starts with FRI- xx xxx. So there is another Friesland in the netherlands. JokeSparrow ... there's no better way to drive! |
