![]() | Home > Maintenance & Modifications > 3rd rear break light - LED version |
bulb swap would be the easiest by far.
Only bouncing an idea but would one of those light pads work, like those umpteen leds that are used to replace interior lights?
I replaced the interior bulbs in mine and used a pad led set up in the rear light in my 110, this came with an adapter to enable it to use the original bulb socket, in my case a festoon fitting. In the packet there were adapters for capless and a small bayonet fitting. What I'm wondering is whether one of these pads could be put in the rear high level brake light housing and an adapter to power it via the existing bulb holder. It would be fairly easy(if your eyesight and dexterity is younger than mine) to take a bulb, get shot of the glass and solder some wires into the base. |
No good, as it would make your center breaklight completely illegal then as it is type approved for incandescent bulb only...... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
In the UK, it's hard to believe that anybody would know or care. Darren
Ok, just a thought, cheapskate that I am
Yes, a bit different than here in Switzerland. The UK apparently is a bit more like France when it comes to things like modifications, etc ![]() ![]() Sorry abt that, could not resist ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Oooh, that's a low blow ![]() Seriously though, and not withstanding the legality of this particular detail, if the rules about modifying vehicles are tightened up in the way our EU colleagues would seem to prefer, it's going to take a lot of the fun out of it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Exactly correct ![]() |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
i have a low-line roof LED brake light...will get that fitted into my roof when i get it done. Putting Dreams on Drives at JLR Solihull..
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
Slightly OT but if anyone has any suggestions for a 3rd brake light for my 90 Soft Top (was pick-up) with a swing-away wheel carrier, then I would be very interested. I've often thought of crafting on a Freelander 1 'Logo' style high level brake light, but I think the fabrication if way beyond me. An off-the-shelf solution would be good.
James ![]() |
Lookers Park Royal workfloor should be able to do that for you, no? ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
NASpec one ???
Yeah, I've been keeping an eye on eBay but have not found one in 2 years! Would be ideal though. James ![]() |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
NAS spec was £300 or more. Freelander 1 like I did on mine 10years ago
![]() ![]() Click image to enlarge |
