![]() | Home > Maintenance & Modifications > 3rd rear break light - LED version |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
This one is at work at the moment, basically a piece of checker plate cut and bent fixed onto the rear swing away ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
At the moment I've used the inside of multi bulbed Hella 3rd brake light inside the original to make it a bit more visable.
![]() Click image to enlarge ![]() Click image to enlarge |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
I have a rear mounted LED stop lamp, its on an older 90 so is in the position where the rear washer jet is on later models.
Got it off ebay, and does make a difference. Yet to fit to my newer Defender - but its on the to do list. Only cost about £15, also has a straight edge so is easy to get horizontal. Just do a search on: LED rear light stop and tail red lens streetfighter or here: http://www.ebay.co.uk/itm/LED-rear-light-s...0893988462 |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
To go back to my OP topic..
![]() ![]() I've found a plinth for 3 at Simmonites, but don't want to replace the traditional indicator, so only want a plinth for 2 lights. ![]() |
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 ![]() ![]() ![]() |
All,
Have any of you looked at these ? http://www.mudstuff.co.uk/products/nakaten...light.html I've got one coming to match my other leds straight swap for standard. "Of Course, Of course, I ain't asking . I'm telling!!" |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Please can you report back your impressions of it?
I'd like one, it's the only incandescent bulb left ![]() |
Me Too,
Will report back but from a quick search on the web hey look to be nice and bright. "Of Course, Of course, I ain't asking . I'm telling!!" |
![]() Click image to enlarge Me Too, Will report back but from a quick search on the web hey look to be nice and bright. "Of Course, Of course, I ain't asking . I'm telling!!" |
Brill, thanks
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
Try forum sponsor Brendan and Barbara 4x4 Overlander had these on a special forum offer a while ago!
![]() http://www.defender2.net/forum/topic47261.html James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
I beat you
![]() My build thread http://www.defender2.net/forum/topic17615.html |
I'm a slow typer...
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
4x4overlander import the LED high level brake light from Nakatanenga into the UK.
They are E marked so are road legal. They are a replacement light unit for the standard high level brake lights. Please note that the standard light unit is mounted on 2 x 6mm studs which are bonded to the glass. Be careful not to overtighten the fixing nuts. Finger tight. Brendan |
