Home > Maintenance & Modifications > 3rd rear break light - LED version
Page 2 of 3 <123>
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Unlike the 7" lamps, which are common to a huge number of vehicles and provide an obviious advantage, a bespoke product compatible with a number of Defenders made since 2002 isn't going to pay for the tooling even.
The only option I can think of to make it cost effective would be to use some sort of rapid prototyping like 3d printing and an existing lamp or go down the generic route already suggested.
How about just changing to an LED bulb? or frenching an LED unit into the roof and removing the high level light from the window all together?
Post #171198 27th Sep 2012 7:48am
T1G UP
bulb swap would be the easiest by far.
Post #171212 27th Sep 2012 8:56am
JWL
Only bouncing an idea but would one of those light pads work, like those umpteen leds that are used to replace interior lights?
I replaced the interior bulbs in mine and used a pad led set up in the rear light in my 110, this came with an adapter to enable it to use the original bulb socket, in my case a festoon fitting. In the packet there were adapters for capless and a small bayonet fitting.
What I'm wondering is whether one of these pads could be put in the rear high level brake light housing and an adapter to power it via the existing bulb holder. It would be fairly easy(if your eyesight and dexterity is younger than mine) to take a bulb, get shot of the glass and solder some wires into the base.
Post #171230 27th Sep 2012 9:40am
ericvv
Post #171233 27th Sep 2012 9:45am
In the UK, it's hard to believe that anybody would know or care. Darren
Post #171240 27th Sep 2012 9:56am
JWL
Ok, just a thought, cheapskate that I am Rolling Eyes
Post #171241 27th Sep 2012 9:56am
ericvv
Yes, a bit different than here in Switzerland. The UK apparently is a bit more like France when it comes to things like modifications, etc Whistle Rolling with laughter
Sorry abt that, could not resist Bow down You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #171243 27th Sep 2012 10:00am
Oooh, that's a low blow Laughing
Seriously though, and not withstanding the legality of this particular detail, if the rules about modifying vehicles are tightened up in the way our EU colleagues would seem to prefer, it's going to take a lot of the fun out of it. Darren
Post #171245 27th Sep 2012 10:04am
mobilecentre
Exactly correct Thumbs Up The lamp would have to be E approved with the test alone costing £2000 after you have done all the design work
Post #171252 27th Sep 2012 10:38am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
i have a low-line roof LED brake light...will get that fitted into my roof when i get it done. Putting Dreams on Drives at JLR Solihull..
Post #171302 27th Sep 2012 4:08pm
Lookers Park Royal
Slightly OT but if anyone has any suggestions for a 3rd brake light for my 90 Soft Top (was pick-up) with a swing-away wheel carrier, then I would be very interested. I've often thought of crafting on a Freelander 1 'Logo' style high level brake light, but I think the fabrication if way beyond me. An off-the-shelf solution would be good.
James Thumbs Up
Post #171307 27th Sep 2012 4:27pm
ericvv
Post #171316 27th Sep 2012 5:00pm
Romadog
NASpec one ???
Post #171355 27th Sep 2012 7:36pm
Lookers Park Royal
Romadog wrote:
NASpec one ???
Yeah, I've been keeping an eye on eBay but have not found one in 2 years!
Would be ideal though.
James Thumbs Up
Post #171359 27th Sep 2012 7:41pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
NAS spec was £300 or more. Freelander 1 like I did on mine 10years ago Thumbs Up
Post #171360 27th Sep 2012 7:45pm
Page 2 of 3 <123>
