Home > Maintenance & Modifications > parting air
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
parting air
A defender is as we know as efficient as a house at cutting through air. Does anyone out there do leading-edge air deflectors for the front wings and leading-edge of the cab. I ask as all I can find on Google is window shields. I'm thinking that if air is redirected horizontally rather than vertically some mpg could be gained?
Any ideas? Rhubarb and custard let fly with their secret weapon.
Post #170903 26th Sep 2012 6:43am
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
A couple of years ago JE Engineering were supposed to be carrying out tests on some sort of aerodynamic modification for the Defender. However, to the best of my knowledge nothing ever came of it which probably indicates that the Defender is beyond help when it come to aerodynamic efficiency.
Post #170911 26th Sep 2012 7:40am
Glynparry25
^^^That is probably about right.
Even if there were things to deflect air you would probably have to do about 30,000 odd miles to recoup the cost of the items Rolling Eyes
Glyn Dog Sheep
Post #170915 26th Sep 2012 7:55am
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Re: parting air
Any ideas?
Streamlining a Defender Rolling with laughter trying to improve fuel efficiency Rolling with laughter thats really made my morning.
Post #170935 26th Sep 2012 9:23am
T1G UP
Re: parting air
Any ideas?
obviously a slow day eh?
Post #170936 26th Sep 2012 9:25am
8x4 sheet of MDF..... place the top end across the windscreen then angle it down over the bonnet.
YOu might need to cut a viewing hole so you can see where you're heading though! Whistle
Post #170940 26th Sep 2012 9:30am
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Drill large holes in the chassis to lighten things up. Much better MPH then.
Post #170945 26th Sep 2012 9:56am
megatoad
You could also strap a Dyson underneath to get more downforce, until of course the plug get yanked out from the socket Very Happy
Post #170946 26th Sep 2012 9:56am
lambert.the.farmer
Omg the positive enthusiasm is deafening. Rolling with laughter
When I come up with an effective solution I'll let you all buy a set at mates rates. Very Happy
And yes it is a slow day, anything to take my mind off laying flags. Rhubarb and custard let fly with their secret weapon.
Post #170954 26th Sep 2012 10:29am
grafty99
It seems any mention of tyring to improve the mpg of a defender is frowned upon. But here i go anyway. Would a lightweight steering guard that is solid without any holes in it help to direct the air under the car and away from the axles? Then it might reduce drag a bit? Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #170959 26th Sep 2012 10:41am
JWL
I'm sure one of the comics took a 90 up to the Britpart headquarters to see how they could get the most mpg out of it. They started off lightening it, putting road tyres on it and it ended up "streamlined" All excess panels were taken off, roof, sides, doors, windscreen anything that would unbolt. Then they shrink wrapped IIRC Kev Mills into it and sent him on his way. I think it got into the high 40's on the mpg front.
I think that to streamline a Defender, the leading edge of the kit will be about 10m out in front of the bumper! It's bad enough pulling out on some of the junctions round here without having to sit even further away from the white line Whistle
Post #170964 26th Sep 2012 10:45am
megatoad
Got one, still only 25mpg, but then there is the roofrack Cool
Post #170968 26th Sep 2012 10:52am
Naks
the most efficient aerodynamic upgrade you can do on a Defender is to put a spare wheel on the bonnet. --
Post #170974 26th Sep 2012 11:49am
K9F
As is getting your haircut, trimming your toe nails, not wearing socks and leaving your undercrackers at home for added weight saving. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #170975 26th Sep 2012 11:56am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Get an old soft-top, put the roof down, screen folded flat, duck behind the steering wheel and use a periscope.
Post #170978 26th Sep 2012 12:09pm
