Home > Maintenance & Modifications > parting air |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
A defender is as we know as efficient as a house at cutting through air. Does anyone out there do leading-edge air deflectors for the front wings and leading-edge of the cab. I ask as all I can find on Google is window shields. I'm thinking that if air is redirected horizontally rather than vertically some mpg could be gained?
Any ideas? Rhubarb and custard let fly with their secret weapon. |
26th Sep 2012 6:43am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
^^^That is probably about right.
Even if there were things to deflect air you would probably have to do about 30,000 odd miles to recoup the cost of the items Glyn |
26th Sep 2012 7:55am |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
Streamlining a Defender trying to improve fuel efficiency thats really made my morning. |
26th Sep 2012 9:23am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
obviously a slow day eh? |
26th Sep 2012 9:25am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
8x4 sheet of MDF..... place the top end across the windscreen then angle it down over the bonnet.
YOu might need to cut a viewing hole so you can see where you're heading though! |
26th Sep 2012 9:30am |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Drill large holes in the chassis to lighten things up. Much better MPH then.
26th Sep 2012 9:56am |
You could also strap a Dyson underneath to get more downforce, until of course the plug get yanked out from the socket |
Omg the positive enthusiasm is deafening.
When I come up with an effective solution I'll let you all buy a set at mates rates. And yes it is a slow day, anything to take my mind off laying flags. Rhubarb and custard let fly with their secret weapon. |
26th Sep 2012 10:29am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
It seems any mention of tyring to improve the mpg of a defender is frowned upon. But here i go anyway. Would a lightweight steering guard that is solid without any holes in it help to direct the air under the car and away from the axles? Then it might reduce drag a bit? 2002 90 Td5 Station Wagon
26th Sep 2012 10:41am |
I'm sure one of the comics took a 90 up to the Britpart headquarters to see how they could get the most mpg out of it. They started off lightening it, putting road tyres on it and it ended up "streamlined" All excess panels were taken off, roof, sides, doors, windscreen anything that would unbolt. Then they shrink wrapped IIRC Kev Mills into it and sent him on his way. I think it got into the high 40's on the mpg front.
I think that to streamline a Defender, the leading edge of the kit will be about 10m out in front of the bumper! It's bad enough pulling out on some of the junctions round here without having to sit even further away from the white line |
26th Sep 2012 10:45am |
Got one, still only 25mpg, but then there is the roofrack |
26th Sep 2012 10:52am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2605 |
the most efficient aerodynamic upgrade you can do on a Defender is to put a spare wheel on the bonnet. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Sep 2012 11:49am |
As is getting your haircut, trimming your toe nails, not wearing socks and leaving your undercrackers at home for added weight saving. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Sep 2012 11:56am |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 652 |
Get an old soft-top, put the roof down, screen folded flat, duck behind the steering wheel and use a periscope.
26th Sep 2012 12:09pm |
