![]() | Home > Maintenance & Modifications > parting air |
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
A defender is as we know as efficient as a house at cutting through air. Does anyone out there do leading-edge air deflectors for the front wings and leading-edge of the cab. I ask as all I can find on Google is window shields. I'm thinking that if air is redirected horizontally rather than vertically some mpg could be gained?
Any ideas? Rhubarb and custard let fly with their secret weapon. |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
^^^That is probably about right.
Even if there were things to deflect air you would probably have to do about 30,000 odd miles to recoup the cost of the items Glyn |
| megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358
Streamlining a Defender |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
obviously a slow day eh? |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
8x4 sheet of MDF..... place the top end across the windscreen then angle it down over the bonnet.
YOu might need to cut a viewing hole so you can see where you're heading though! |
| Thud Member Since: 21 Jul 2012 Location: London Posts: 667
Drill large holes in the chassis to lighten things up. Much better MPH then.
You could also strap a Dyson underneath to get more downforce, until of course the plug get yanked out from the socket |
Omg the positive enthusiasm is deafening.
When I come up with an effective solution I'll let you all buy a set at mates rates. And yes it is a slow day, anything to take my mind off laying flags. Rhubarb and custard let fly with their secret weapon. |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
It seems any mention of tyring to improve the mpg of a defender is frowned upon. But here i go anyway. Would a lightweight steering guard that is solid without any holes in it help to direct the air under the car and away from the axles? Then it might reduce drag a bit?
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
I'm sure one of the comics took a 90 up to the Britpart headquarters to see how they could get the most mpg out of it. They started off lightening it, putting road tyres on it and it ended up "streamlined" All excess panels were taken off, roof, sides, doors, windscreen anything that would unbolt. Then they shrink wrapped IIRC Kev Mills into it and sent him on his way. I think it got into the high 40's on the mpg front.
I think that to streamline a Defender, the leading edge of the kit will be about 10m out in front of the bumper! It's bad enough pulling out on some of the junctions round here without having to sit even further away from the white line |
Got one, still only 25mpg, but then there is the roofrack |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
the most efficient aerodynamic upgrade you can do on a Defender is to put a spare wheel on the bonnet. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
As is getting your haircut, trimming your toe nails, not wearing socks and leaving your undercrackers at home for added weight saving. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655
Get an old soft-top, put the roof down, screen folded flat, duck behind the steering wheel and use a periscope.
