![]() | Home > Puma (Tdci) > NAS reversing & rear fog light each side. |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
you'll just need to run supplies over the other side for both.
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
Couldn't be done isn't something you often hear at any Land Rover specialist. It's not even that difficult. You just need to take a parallel feed from the nearside to the off side for the fog and vice versa for the reversing light. Any auto electrician could sort this for you. |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
Due to the same chassis loom being used for LHD and RHD for some applications... you might find the wiring is already there!
If not, just be careful about how much current draw you are putting on the standard wiring... or fit a pair of LED NAS fog and reverse lamps - which are not only brighter, but draw a lot less current. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
On my 51 reg TD5, the wiring/sockets for fog/reverse lights are on both sides. So it should be plug and play, subject to current draw...
Cheers Simon |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
Click image to enlarge lights like this always remind me of the old toyota supra Last edited by farmer giles on 25th Sep 2012 10:30am. Edited 1 time in total |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
I like the idea, it should give you more light when reversing without the need to fit a flood light.
And it does make the vehicle look balanced 2011MY 110 XS USW Black |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
I think side lights in the fog lights would look good. Increase rear visibility too
A set of indicators and stop/tail lights mounted high up in the back of the roof make you more visible
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
On one of our Defenders we did have high mounted indicators and brake lights at rear.
However just had a look at the regs about maximum height Indicators [
Now are roof mounted indicators on a Defender 100% within the regs?? Brendan |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Given this bit:
You could argue that they're legal on a SW that has glass in the rear quarters but not on a USW that has a flat panel. However, as they would be supplementary to the the OE ones, then it could also be argued that the regulations have already been satisfied. It would be different, of course, if they were the only rear lights. In practice, there are lots of vehicles with these sorts of repeater lights higher up, from ambulances and recovery trucks to coaches and tank wagons, so I doubt that there's too much to worry about. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Not going to much into it, they are talking about fitting a single set, here were talking about fitting additional light that more than meets the legal requirement.
What plod will pull you for having 2 sets rear of indicators like the disco 1's? Russell 2011MY 110 XS USW Black |
my 300 had the two sets...much better than just in the bumper. |
Although I see the point of having 2 reversing lights I don't like cars with 2 fog lights.
The worst of which are Fiats which often have 2 close together which, when they are the only thing you can see through the fog, give the impression that the car is further away than it really is! |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
How I want my 90's behind to look. |
