Home > Maintenance & Modifications > Removal of Cubby Box
fidocrew
United Kingdom 1998 Defender 90 300 Tdi CSW Epsom Green
Can any one explain how you remove the orginal Cubby box from a TD5 2002 90?
do you need to remove the two screws under the front edge? if so how do you do this?
Rolling Eyes
Post #168623 15th Sep 2012 9:21pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
The cup holder pulls out for the front 2 and the reat 2 are in the cubby boc covered with blanking plates.
HTH
Ben 2002 Defender 110 DC
Post #168627 15th Sep 2012 9:36pm
mk1collector
Sometime the clips that the screws screw into start to spin so you either have to send someone underneath with some grips or give it a good yank
Post #168681 16th Sep 2012 9:50am
K9F
I had the same....one of the rear rivnuts started spinning. Mole grips underneath and once removed gave the rivnut a squeeze to tighten it....Job Jobbed! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #168685 16th Sep 2012 10:14am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
On the same subject, will a Mantec cubby box be a direct fit? ie, do the holes in the Mantec box fit the holes in the top of the seat box, or will I need to drill some more? Euro-Leafing to infinity and beyond.....
Post #168762 16th Sep 2012 8:05pm
