![]() | Home > Maintenance & Modifications > Removal of Cubby Box |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
The cup holder pulls out for the front 2 and the reat 2 are in the cubby boc covered with blanking plates.
HTH Ben 2002 Defender 110 DC |
Sometime the clips that the screws screw into start to spin so you either have to send someone underneath with some grips or give it a good yank
I had the same....one of the rear rivnuts started spinning. Mole grips underneath and once removed gave the rivnut a squeeze to tighten it....Job Jobbed! If you go through life with your head in the sand....all people will see is an ar5e!!
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1400 ![]() ![]() ![]() |
On the same subject, will a Mantec cubby box be a direct fit? ie, do the holes in the Mantec box fit the holes in the top of the seat box, or will I need to drill some more? Euro-Leafing to infinity and beyond.....
