Home > Puma (Tdci) > Penrite Oil
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Penrite Oil
Hi I realise there has been oil discussions before but I just needed to check if this oil is Ok for the Puma Engine
I had used it in the TD5
Penrite HPR Diesel 5
Sae 5-40
API Ch_4/SL
ACEA A3/B4/d4
DLD-3/DLD-2
thanks in advance SImon
Post #12271 23rd Jun 2009 7:58pm
dgardel
Italy
Re: Penrite Oil
ACEA A3/B4/d4
........thanks in advance SImon
Not good!!!
You must use an 5W30 ACEA A1/B1 or, better A5/B5 like Castrol A1 Professional 5W30.
A1/B1 and A5/B5 is low HTHS (hths from 2,9 to 3,5) and engine designed for this oil are the main bearing tickness dery low.
if you use ACEA A3/B3/d4 (HTHS > 3,5) on the long distances you could have bearings wear problems.
see at http://www.lubrizol.com/EuropeanEngineOils/A5B508.html
Post #12275 23rd Jun 2009 8:54pm
sasha2001
thanks I suspected as much, i will get the correct stuff!
Post #12277 23rd Jun 2009 9:16pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
NO! OK for a 300Tdi but not for the Puma.
Australian spec from dealers is Castrol Magnatec Pro 5W-30 which equates to Castrol Edge in the consumer market of which the 0W-40 is the Castrol recommended spec equivalent, the Edge 5W-30 also meets the spec's.
http://www.castroledge.com.au/ 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #12289 24th Jun 2009 10:33am
dgardel
Italy
Castro EDGE SPORT 5W-30 (from www.castroledge.com.au) is ACEA ACEA A3/B3/B4 (HTHS>3,5) so IS NOT GOOD FOR PUMA
You must use CASTROL MAGNATEC 5W-30 A1
http://www.castrol.com/castrol/productdeta...Id=7027374
or an oil that met Ford WSS-M2C913-B
Post #12291 24th Jun 2009 11:04am
sasha2001
Thanks we have the magnatec here
Post #12294 24th Jun 2009 11:39am
MK
Application
Designed for use in latest generation petrol engines
such as multi-cam, multi-valve, turbocharged and
supercharged engines including the new high output
European and Japanese engines. Also
recommended for engines with variable valve
timing. Specific applications include MG-F, MG-TF,
MG-ZT, post 1998 vehicles manufactured by Volvo,
Subaru and SAAB, high performance Japanese cars
and other vehicles that specify the use of SAE 5W-
30, 10W-30 or 5W-40 oils in the owner’s handbook.
HPR 5 can be used where the ILSAC GF-3/GF-4,
ACEA A1/B1 and A5/B5 fuel economy specifications
are specified
While HPR 5 is suitable for use in many diesel
powered vehicles, HPR Diesel 5 is our primary
recommendation in this viscosity range.
Customer Benefits
• Greater engine protection at operating
temperatures compared to 5W-30 oils due
to higher operating viscosity.
• Longer engine life by reducing formation of
high temperature engine deposits.
• Longer oil life and less oil consumption
versus similar man-made synthetic oils due
to the use of advanced hydroprocessed
base oils.
• Low start-up viscosity provides engine
protection and power/fuel economy
retention at the most critical time of the
engines run cycle.
Industry Specifications
Penrite HPR 5 meets the performance requirements
of:
API SN/CF ACEA A3/B4 (Europe)
SAAB Mercedes Benz 229.3
GM 4718M (Corvette) Renault
Rover RES.22.OL.22 VW 502.00/505.00
Volvo Chrysler MS-6395G
Ford M2C912A, M2C913A/B GM-LL-B-025
Ford M2C153-G/H Opel B040 2095 Puma 110" SW
Post #96903 29th Oct 2011 10:27am
