![]() | Home > Puma (Tdci) > Penrite Oil |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Hi I realise there has been oil discussions before but I just needed to check if this oil is Ok for the Puma Engine
I had used it in the TD5 Penrite HPR Diesel 5 Sae 5-40 API Ch_4/SL ACEA A3/B4/d4 DLD-3/DLD-2 thanks in advance SImon |
Not good!!! You must use an 5W30 ACEA A1/B1 or, better A5/B5 like Castrol A1 Professional 5W30. A1/B1 and A5/B5 is low HTHS (hths from 2,9 to 3,5) and engine designed for this oil are the main bearing tickness dery low. if you use ACEA A3/B3/d4 (HTHS > 3,5) on the long distances you could have bearings wear problems. see at http://www.lubrizol.com/EuropeanEngineOils/A5B508.html |
thanks I suspected as much, i will get the correct stuff!
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
NO! OK for a 300Tdi but not for the Puma.
Australian spec from dealers is Castrol Magnatec Pro 5W-30 which equates to Castrol Edge in the consumer market of which the 0W-40 is the Castrol recommended spec equivalent, the Edge 5W-30 also meets the spec's. http://www.castroledge.com.au/ 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Castro EDGE SPORT 5W-30 (from www.castroledge.com.au) is ACEA ACEA A3/B3/B4 (HTHS>3,5) so IS NOT GOOD FOR PUMA You must use CASTROL MAGNATEC 5W-30 A1 http://www.castrol.com/castrol/productdeta...Id=7027374 or an oil that met Ford WSS-M2C913-B |
Thanks we have the magnatec here |
