Home > Maintenance & Modifications > Mobile auto electricians?
Page 2 of 2 <12
RRUK
Martin wrote:
Looking at the Td5 wiring diagrams, the smallest diameter cable is 0.5mm^2 thinwall per seat.. I would wire up with 1mm^2 thinwall per seat.
Martin,
Have been looking through Polevolt.co.uk at their cable (as they seem to be the only people who do such thin-thinwall cable, everyone else like Autosparks start at 2mm).
Is this the right spec?
Ref: TW1.0
Thinwall cable 1.0mm.
Operating temp -40 to +105 deg.C. Maximum working voltage 60v.
Nominal current rating 16A. (Derate for long lengths)
Resistance per metre at 20 deg. C: 0.0185R.
Plain copper conductors (32/0.20mm).
Maximum overall diameter of cable 2.1mm.
Sold in multiples of 1mtr.
Price per metre: £0.26 (£0.31 Including VAT at 20%) 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #162409 16th Aug 2012 6:50pm
Martin
Site Admin
The best priced thinwall cable I've found is on eBay.
1mm^2 thinwall is rated at 16A so that looks correct.
The fusebox/relay end is the most tricky, correct, but worth the effort.
I'd give you a hand if you were a little closer Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #162414 16th Aug 2012 7:05pm
K9F
RRUK wrote:
do you need a special tool for crimping or insertion or just a standard crimping tool?
"Molex Crimping Tool" is the correct terminology. They are not cheap and if you know someone in the trade or has access to one a 'loaner' is the best and cheapest option.
With care and patience you can very carefully use a small pair of needlenose pliers to crimp the crimps. The two tabs at the rear have to be rolled around the insulation which can be fiddly. Buy extra Molex crimps and practice first. If you have a decent motorcycle shop and or electrical workshop near you you may be able to 'borrow' a tool with a suitable contribution. I did initially.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #162417 16th Aug 2012 7:23pm
RRUK
Any tips on what connectors to purchase for the fuse box end? I have the other bits and cable earmarked now.
I read that thread from PaulMC and the detailed photos but he doesn't give away what the connectors are called or who makes them.
i.e these:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2016 D4 HSE
Post #162418 16th Aug 2012 7:24pm
RRUK
K9F,
Are Molex crimps also known as uninsulated terminals? My budget crimpers have slots for uninsulated. With practice I could probably do a decent job, I'm not a ham fisted oaf Cool 2016 D4 HSE
Post #162420 16th Aug 2012 7:26pm
Martin
Site Admin
Adam - I may have a fuse box terminal kicking around somewhere but I would have to find it first Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #162421 16th Aug 2012 7:27pm
RRUK
If the fuse box end gets tricky I guess I could resort to an in-line 20A blade fuse instead? 2016 D4 HSE
Post #162422 16th Aug 2012 7:30pm
Martin
Site Admin
Yes but you still need to feed it from somewhere ignition switched Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #162424 16th Aug 2012 7:34pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
Have a look at these. I've used them before, they work quite well.
http://www.ebay.co.uk/itm/Add-A-Circuit-Fu...2a14b1c2ff
Allows you to add to the existing fusebox without splicing into anything. As long as you're not overloading the main incoming supply.
Post #162429 16th Aug 2012 7:41pm
K9F
RRUK wrote:
K9F, Are Molex crimps also known as uninsulated terminals? My budget crimpers have slots for uninsulated. With practice I could probably do a decent job, I'm not a ham fisted oaf Cool
NO! Budget pliers are no good. Below is a picture of the type of plier jaws you need. The 'W' or 'M' shape in the jaws is what bends the two rear tabs to grip the insulation.
Post #162431 16th Aug 2012 7:42pm
PaulMc
i.e these:
They're Grote & Hartmann (now owned by the Lear Corporation) AFK terminals.
I can supply them for £0.50 each.
I have them to suit three different cable sizes.
More details in my post here - http://www.defender2.net/forum/post96207.html#96207
That post also gives details on how to insert them into the fuse box.
I can also supply the Black and Green 5-way switch connectors (the TD5 Defender uses a LH and a RH heated seat switch, one uses the Black connector, the other uses the Green connector).
I can also supply the proper seatbox male connector to mate with the connector on the trailing lead from the heated seat.
You can crimp most of these terminals with an el-cheapo non-insulated crimper, such as the D1 from VWP, or the TT70 from Polevolt.
But for small terminals found in MQS connectors (heated seat seatbox connectors), you really do need a more specialised crimp tool.
I can supply the seatbox MQS connectors pre-crimped to 0.75mm² cable of whatever length you require.
Wiring between the heated seat switches and the seatbox connectors is 0.75mm², which is the largest cable size that these connectors will accomodate.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #162433 16th Aug 2012 7:46pm
Martin
Site Admin
If I can't find a fuse box terminal then Ref: 3-8441/10 here looks likely http://www.polevolt.co.uk/acatalog/Termina...tions.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #162434 16th Aug 2012 7:46pm
PaulMc
Polevolts 3-4647 is a closer match -
http://www.polevolt.co.uk/acatalog/Single_Fuse_Holders.html
...and fits perfectly.
I used to use these for TD5 fuse boxes.
. Paul.
Post #162441 16th Aug 2012 8:00pm
Martin
Site Admin
Cheers Paul Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #162443 16th Aug 2012 8:05pm
RRUK
Paul,
YOu know your onions Thumbs Up
Would you be willing to put together and price up a little kit to wire these in? I already have the 5 way switch connectors on order.
If so can you PM me a price for the male MQS connector to go directly onto the heated seat trailing leads (x2 obviously) pre crimped with say a metre each? I can solder the wires and heatshrink no problem.
Also, some 0.75mm cable long enough to enable me to wire them up going via the floor panels
Some AFK Terminals x 10 so I have some spares
Knowing I have all the bits to complete the job would be great. 2016 D4 HSE
Post #162446 16th Aug 2012 8:24pm
Page 2 of 2 <12
