![]() | Home > Puma (Tdci) > Intercoolers for Puma 110 |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
i waited over 3 weeks for the batch which mine was in to be made but could not fault andys services once it was ready
remeber having something made to order is alittle different to buying of the shelf i soon may have my serch one from alive up for sale ? steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Andrew DefenderBits Member Since: 15 May 2012 Location: Somerset Posts: 43 ![]() ![]() ![]() |
We can supply the Terrafirma units as we are Terrafirma authorised distributors, these are in stock with Terrafirma (as of the date of this post) so we can get them next day and then on to a customer on a next day service via Fedex in the UK or 2-3 days if you live up a glen in the highlands
Do let me know if anyone is interested prices £349+vat and £5.95 for next day delivery |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Thanks.
I must say since I complained they have made every effort to keep me updated so I am a lot happier now that I know what is happening. |
Just an update. I received my intercooler and wow it is very nicely made. I will be fitting it this weekend so looking forward to seeing if I can feel any difference.
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Keep me in the loop, please.
Will do Rob. I will try and do a step by step fitment as well as let you know the results if I can feel any. I did monitor my engine temp and my intake temperatures vs outside temps this past week in Botswana so will be able to get a more or less feel if there is an improvement.
Thanks. Did you get the silicone hoses as well?
no just the inter coolers.
OK so I fitted the inter-cooler this weekend. Was quite a fiddle but eventually I did it in about 2 hours and I only have one scar on one knuckle, and I didnt do much swearing, so didnt do too badly.
![]() It fitted perfectly and is very well made. I would say the hardest part was to cut the tabs off of the radiator in order for the inter cooler to fit. I haven't had a chance to properly test it yet but am not expecting too much and doubt I will feel anything different. I will measure the intake temps when the temperatures in SA get a bit higher though. I was also surprised at how dirty my radiator was so took the opportunity to clean it also. If I knew how to post pictures on this forum I would. ![]() |
Here is a report back on my Puma's first road trip. To Sum up, I have no regrets and am very happy with the intercooler's performance.
This week I had to go to Maputo so it was a perfect time to test it out. (roughly 580kms from JHB) The below is probably not 100% accurate but its close enough to give results. I experienced ambient temps ranging from 7 deg C to 37 deg C. I can not tell or measure if there is more power but everything is running cooler and I definately think there is better cruising power: - water temps never went above 92 deg and this was when sitting in traffic in Maputo. - at 115 kph the water temp never went above 85 degC normally I would be at around 90. - now here is what you waiting for... Intake temps never went above 32 degC and this was also in traffic in Maputo. The intake temps seem to stay within 1 to 2 degC of ambient. When at speed its below ambient and at slow speeds its above. While driving around in traffic it went up but when I travelled at speed it would drop between 4 and 8 degC fairly quickly. - call me insane but fuel consumption is also better averaging at 9.8 ltrs per 100kms for the trip. I did drive harder than what I normally would have. Normal is mid to high 10's per 100km. While doing the pass just before Nelspruit I a TD5 caught up to me. He was also alone but had 4 jerry cans on his roof rack. I had nothing. He could not stick with me on the hills, so much so that I left him behind and never saw him again. I can't compare this to pre intercooler but there is a huge difference in performance between TD5 and Puma. On hills where I dropped down to around 90 kph I would guess he dropped down to 60kph. Over all the intercooler made everything run cooler. Perhaps it would be a good idea for me and another standard Puma to drive somewhere together to compare temperatures at the same time. (Regard?) Oh and on the detour through Kruger I saw a pride of Lions on the hunt and sat within 3 meters of 7 cubs who were waiting for their lunch for at least half an hour - nothing to do with the intercooler though. |
![]() ![]() ![]() Nice and usefull report Bruce thank you!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
My pleasure.
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
You forgot to mention the altitude.
Johannesburg is at around 1500 meters above sea level and Maputo is at Sea level. The highest temperatures were in Maputo.
I also noticed the EGR valve worked alot more than in Johannesburg where it never works except when its doing a self cleaning cycle. |
