![]() | Home > Puma (Tdci) > 2007 Defender Blower Switch |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Knowing LR, that switch is probably used on mid 90's Rover cars, so a hunt around a scrappy will probably turn one up cheap.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Contact Shukers parts they have a part request on their site. You will normally get a reply from a chap called Neil I needed a heater re-circ cable and he sorted that for me. The prices are better than expected too!!
Good luck ![]() You could also phone of course. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Ed welcome to the madhouse!
![]() Take your pick! ![]() http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html http://www.reedx.net/landrover/mods/2002dash/part5/index.htm http://britishparts.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Eddy1976 Member Since: 26 Jun 2012 Location: S Wales Posts: 3 ![]() ![]() ![]() |
Thanks Guys you have provided me some direction for my search!!
Ed. |
Looking at my microcat the heater switch is part #JFC500840 and £88.10 (last months price)
edit: that might just be the "control" panel that adjusts windscreen to feet and temparature, not the actual fan switch.... will keep looking! |
All done
![]() Contacted shukers and they (Neil) were spot on - had to but the whole heater panel but Neil gave me a good deal and had it delivered the next day. Steve - Thanks for the tip. Thanks all for your advice. Ed |
Your more than welcome. Glad your now sorted. ![]() Steve ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
any clever sparks out there that could make a switch that was like on a slider so you could have half speed or any speed as mines a little noisy on 1?
Rotary or linear potentiometer switch is what you need rather than a switch that has fixed resistor values at each position.
http://www.potentiometer.com/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
would love it to relace the original switch and look stock? so i guess a linear potentiometer? can you pick one out K9? i don't know what i'm looking at |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
My switch had just jammed in position 3, so I looked up the price of this now. It's gone up by approx 500% since the quoted post, 18 months ago, and now costs a staggering £433 ! ![]() ![]() I don't suppose anyone has a broken take-out I can have to break for parts? I only need the fan switch. |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
I removed mine when it was stuck on position 1 and with a stanley cut the plastic that was melted away. A wee bit of emery paper and some contact grease and its been fine ever since. Beats me how they melt though. William
Sorted! The top centre bulb had melted the edge of the slider and caused it to deform and catch one of the guides. Stanley knife to the rescue, now works better than ever before.
That top bulb actually touches the slider, and it looks as though mine was starting to fail and had got brighter, therefore hotter. I have decided to omit the bulb in that position (which isn't really needed) to prevent a recurrence. Only a Defender could include design of such brilliance that a faulty 16p bulb can knacker a part which costs £431! |
Those bulbs are a pain! I've often wondered if there are some (non directional!) modern LED alternatives that display just as good.
I'd give it a go anyway if the dash wasn't such a pain o mess around with. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
